I am in the process of getting a 1990 HCR32 Skyline GTS Type S (Sedan) and I have a few questions I am hoping someone can answer.
Is there a R32 Skyline GTS or GTS-T service manual? I have the GT-R manual and the RB series engine manual, but this document is NO WHERE online. Every topic here and elsewhere the links are all dead and are a decade or more old.
What transmission does the GTS and GTS-T use? As per this blog it says that the R32 and R33 GT-Rs used the Nissan(FS5R30A). Did the GT-R and GTS-T use the same? Are GTS-T parts compatible with the regular GTS?
It says that the 300ZX transmission parts are pretty much exchangeable with the R32 and R33 GT-Rs but does that also go for the GTS and GTS-T?
I am mainly wanting to get all my ducks in a row and the information lined up before hand in case any problems pop up and I am caught off guard.
The GTR manual is pretty much suitable for the GTSt. Doesn't cover 2WD stuff obviously, but it covers GTS4, which is RB20DET, so you get pretty much all of the GTSt stuff you need except gearbox.
GTS uses a flimsy gearbox related to the 4 cylinder boxes. GTSt is basically the same box. These are tiny boxes compared to the big tough RB25DET box. The RB25DET box is basically the same as the front half of the GTR box. The Z32 boxes are related to the RB25DEt and GTR boxes, but obviously with VG bellhousing (which is the whole front half of the casing).
You cannot mix and match anything from small gearboxes to big ones.
Some (many) of the parts from big boxes go back and forth. AWD boxes are obviously different in many ways. They have a transfer case, so the output end is different, the shifter is different, the mounts are different.
All of this information is available on here in spades! Just search. It's been >20 years since this forum started.
This may be an incredibly ignorant question but let's say that something fails on my GTS transmission and the entire thing needs to be replaced. Would I be able to replace it with a GTS-T transmission or a GT-R transmission? Also since the GTS and GTS-T uses such a similar transmission can I source transmission parts from it?
Yes. Basically the same thing.
No, because AWD.
Why bother? Break the gearbox, then replace engine and gearbox with LS1 & T56.
No, because AWD.
Sorry but when you say LS1 all I can think about is the Corvette engine. That's not what you mean right?
10 hours ago, redm0th said:
Corvette engine
10 hours ago, Ben C34 said:
Yep
But we don't think of them as a Corvette engine. They were a family car engine here. They're lying around in piles. Much better idea than trying to upgrade to any RB option.
Simple answer is most RB manual gearboxes are a direct swap for each other; exceptions being AWD and RB25DET boxs.
So anything RB20E/ET/DE/DET will fit, RB30E box will fit (VL Turbo RB30ET box is larger), RB25DE box will fit. Same applies to non-skyline chassis, e.g. Cefiro, Laurel, VL Commodore.
There are theoretically minor internal differences between RB20 turbo and non-turbo gearboxes (e.g. double synchros on first and second in most 'turbo' boxes, differences in case reinforcing webs), in practice they don't always apply and don't really matter.
Edited by floody
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
