Hi Guys,
It's finally happened, after 20 years the MFD screen has died.
- after start up screen turned on, then faded/dimmed, then went completely black after a few minutes
- took MFD apart, found the fuse has blown, replaced fuse  (with 15.8mm x 4.8mm 1.5A, fast blow)
- reconnected to test, screen turned on like new nice and bright
- after 3 minutes, screen faded/dimmed again (like it's on 3-5% brightness)
- took it apart again, fuse intact (did not blow), what could it be???
https://www.sau.com.au/forums/topic/480738-bnr34-mfd-fadeddimmed-screen/
The screen is likely faulty. Early models used a Sharp lcd screen and then Nissan changed to a Toshiba screen. I know the Toshiba is a universal screen  TFD58W30MM I purchased one off Aliexpress and it works perfect, all plug n play.
Edited by NZ-GTT
