I ask because I currently have a 9.0:1 3L VL, with max power at 5200rpm and am looking forward to 7000rpm when I install the rb25 head, etc. I'm just concerned about how much boost I will eventually want to run, and the lag I'll experience with the low CR. The extra revs will mean I could stroke the engine and still increase the redline. I was originally looking at building a high CR N/A engine but the expense has led me to aim at forced induction from the start :)
https://www.sau.com.au/forums/topic/48074-rb30-stroker/#findComment-968772
Sorry, I realise this, but I have always planned on throwing the twin cam head on my engine, therefore installing new cams into my current engine would be a waste of money. When I build the engine I will rebuild the block as well as the head, which means when the head goes on, the higher possible revs will be acheved at the same time. I am talking more about piston speed when I ask about stroking the engine. I'm not so much worried about the cams or engine rpm at this stage.
https://www.sau.com.au/forums/topic/48074-rb30-stroker/#findComment-968919
Sorry Roy, I didn't put that very clearly. The redline of my engine after it's built will be much higher than it currently is, by roughly 2000rpm. This means that when I build the engine, if it was stroked at the same time, it is possible that I could still increase the rev limit over the current 5000 odd. If the engine was stroked, it is possible that it won't rev to 7000ish very happily, but it will still rev higher than it does now. Does that clear it up?
https://www.sau.com.au/forums/topic/48074-rb30-stroker/#findComment-969599
A bit of RB30 data to start with...
Bore = 86 mm
Stroke = 85 mm
Rod length = 152.5 mm
Rod stroke ratio = 1.793
In order to get to 3,208 cc's you would need 92 mm stroke with 86 mm bore. That's 3mm shorter rods so the rod stroke ratio would be 1.625. Because of the increased angles, the shorter conrods have to be stronger to handle the side loadings. This means extra weight and more stress on the piston skirts and bores.
You have to buy a custom crank (~$4K) and a set of custom conrods (~$3K), plus a set of forged pistons ($2K).
My suggestion (and what we do) is to go for a larger bore, 87.5 mm with the standard stroke. This gives you 3,068 cc's for around half the cost. We rev them to 8,500 rpm with 900 bhp capability. That's good horsepower per dollar. :D
https://www.sau.com.au/forums/topic/48074-rb30-stroker/#findComment-969691
Thanks for the info SK. The piston speeds must be huge in RB30s doing 8.5 grand?? I couldn't be bothered working it out.
Basically, what I want to achieve is a really strong, flexible street setup, with the option of drag racing and maybe some track work.
https://www.sau.com.au/forums/topic/48074-rb30-stroker/#findComment-971163
    • You're not wrong but 5W30 at 100C is like 10 cSt vs 25 cSt for 10W60. If we think in terms of viscosity margin 10W60 will probably still be ok at 130C but 5W30 is probably too little. It's absolutely shocking how hot the oil gets in something like a stock FL5 from only ~3 minutes of use on the Nordschleife. I would not risk taking a car like that to anything remotely intense without a ton of work done for cooling. Heat shielding on the manifold/turbo/downpipe, oil coolers, etc.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
