Various Rb/Vl/R33 parts for sale including R33 rolling shell clean tiitle
Twin entry 100mm GTR cooler used for fitment only $250 ono.. cheap
BnM shifter cover $50 new never used
BnM shifter cable brackets various GM ford etc unopened $20 firm
Brightline  Vl stainless drop box suits earlier pro ratchet without mods  or stealth with cable clearance modifications , correct positioning holes drilled for either  $120 as new cond - sold
R33 manual crossmember $100
R31 manual crossmember $70
Vl manual crossmember $100-sold
R33 good condition afm $50
3.5inch stainless muffler new never fitted paid $180 - $100 firm
R33 s1 driving light/blinkers (one has bit of plastic broken at the back but fine) not sure what there worth make an offer
R33 steering rack, brought years ago as a spare been in storage arms are strait etc should be fine $120
I have a full stainless 3 inch cat back exhaust to suit an R33 skyline fits mint, maybe xforce for memory, cat back section still on car, dump is in pictures $300
Diff back stainless cannon mild pipe $50
Rb30 s1 head, came off running engine (I just needed crank only) needs a clean has been sitting comes with cover $100ono
R33 radiator out of running R33 no leaks at time of removal $30
I have a clean title R33 rolling shell missing only running gear, clean interour good condition seat roof lining dash etc, body is average, could put engine in and paint etc for rego, or make a good drift car $2k ono will get pictures on request
https://www.sau.com.au/forums/topic/480740-rb33-parts-and-rolling-33-car/
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
