47 minutes ago, joshuaho96 said:
I'm actually just hoping to be able to get an RB to be more modern, running something like high 13 AFR deep into boost and revs instead of 11.5 and maybe push back the knock limit enough to get power equivalent to 98-100 RON fuel with 95 RON. RBs also seem to be thermally challenged so water injection might help in that regard as well if it ever makes it to a track. But if the trade-off is I never actually get to drive the car or I have to pull the engine because water contaminated the oil and trashed the engine it isn't really worth it.
You are a funny guy
  • Haha 1
E85 done, less thinking and stuffing about.
You can put timing way past MBT and start losing power on a RB with E85 and it won't even produce any knock.
Anyways back on topic, 10:1 would be sexual. I would still keep the squish pads in there though.
Disclaimer: Not a professional engine builder. You'll need to CC your parts to verify these calcs, this is assuming the stock Neo head has a 51cc chamber and you will also want to verify piston to valve clearance.
Playing around with a compression ratio calculator (I've been using https://goodcalculators.com/compression-ratio-calculator/) I'd say an 8.5:1ish R33 RB25DET piston would be a good starting point. I can see two fairly easy/reasonably cheap options so far:
Option 1 - ACL aka Ross aka Mahle 6MKRY9603 with 11.5cc piston dome. Set to zero deck height with a 1.3mm head gasket on a Neo head this should give a flat 10:1. If you bring the pistons 0.5mm above deck you can achieve around 10.5:1 with the same 1.3mm HG while keeping quench around 0.8mm - I've heard 0.7mm-1.2mm being a rough rule of thumb to aim for. Each 0.1mm gasket change on this combination is roughly 0.15 change in CR so you should be able to fine tune the CR easy enough.
Option 2 - Wiseco K578M865AP with 14cc piston dome. At zero deck this will give 10.4:1 with 1.3mm HG. With +0.5mm deck height this will give 11:1. As before a 0.1mm change in HG thickness will change the CR approx 0.14-0.15.
Hopefully this gives you a starting point.
  • Like 2
2 hours ago, Ben C34 said:
You are a funny guy
I like to spend my hours reading about interesting things, not necessarily productive though.
Feels like this has been the answer a number of times I've looked into this. I'm probably going down that road in the end, just want to figure out a good 340 lph brushless in-tank pump solution.
Walbro F90000267 and call it a day (or F90000274 if you're running stupid high base pressure & big silly boost)
That is a properly buff pump but probably too much fuel pump for something making 300 kw. Something like the Fuelab 48402 seems to be what I'm looking for, around 10A draw and capable of 300 lph at 70 psi outlet pressure to be able to turn up the FPR to 3.5 bar differential pressure. I might run some experiments to see if the OEM FPCU/FPCM has the right resistances to be able to actually function as the pump speed controller, have to see what the impedances look like. Probably have to just accept that it's a horrendous idea though and just use a standalone ECU to run the PWM controller.
Anyways, I don't doubt that high CRs improve driveability, I'm just skeptical that you can run high CR with low duration cams and no tricks like advanced VVT/cooled EGR/E85. I'm sure that Mitsubishi and Nissan would've raised the static CR on the 4B11T and VR38DETT to 10:1 if they could've done so while meeting power targets on pump gas. The VR30DDTT has a 10.3 CR but uses GDI and dual VVT to get there.
Don't waste your time, you'll end up killing the pump with the OEM setup. PWM is the only way, not a drop resistor (like how the OEM garbage works).
1 hour ago, GTSBoy said:
Emissions.
Doesn't that imply that you would have to run rich for too much of the load/RPM map? Modern gasoline is up to 14:1 CR for NA, or even as high as 16:1 for the Skyactiv-X, as high as 12:1 for turbo. I can't think of why emissions would factor into it. NOx obviously goes up with high CR, but 10:1 PFI-T is nowhere near what diesels have done for a long time now.
You're knock limited with port injection, thus running it leaner is not possible. With direct injection you get better atomisation, cooling effect of fuel being compressed at high pressures then decompressing in the chamber, thus your knock threshold is much higher.
Doesn't this imply that you would want less CR anyways? I can't imagine running rich all the time is healthy for an engine.
NOx is the big one.
Diesel combustion temperatures are quite different to petrol, both at partial load and at full load. Diesel runs very lean at partial load so has different NOx problems than petrol does. Hence why they're down the Urea injection rabbithole these days.
For OEMs trying to meet Euro and US emissions regs, fuel consumption targets, engine life expectancy & warranty boundaries, the space they have to work in is a very tiny portion of the N-dimensional space. So they can't have a combination of high SC and boost and not give up ground in at least one of the other dimensions of their design space. It's a bigger nastier version of "cheap/fast/light pick any 2".
  • Like 1
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
