Hi everyone,
Ive done a search, though I cant find exactly what  I'm asking here. The cold start valve(under the TB on the rb20det), what voltage does it see at the plug? Is it 12v? And when does it see a voltage? Cold engine, ignition on(engine not running), should I be seeing a voltage at the plug for the valve?
Im not getting a voltage under this scenario, if I'm  suppose to, any ideas on where to look to fault find this? I've finally had enough of the horrible cold starts and rough warm idle problems and I'm finally doing something about it.
Thanks everyone!
https://www.sau.com.au/forums/topic/480775-cold-start-valve-wire-power-voltage/
Ok, so this means it should have a constant 12v signal with ignition on? The fuel pump fires up and runs, so its getting a signal to run.
Ive pulled the cold start valve apart, its dead clean inside, I've hit it with 12v and nothing happens. I can move the pcb with my hand forward and back against the spring, though I'm not sure what normal operation is meant to be with a 12v signal.
Thanks
It's super slow acting valve, not something that reacts fast like your idle control valve or similar.
They often die on RB20DETs and you see hacks where people just block the air feed to it to prevent super high idle.
11 minutes ago, mtopxsecret6 said:
Does anyone know which is positive and negative on the plug?
Thanks
test which terminal has continuity to earth = -ve
Easiest to test if you remove it.
Look through where the hoses fit. There should be a shutter, and it should be roughly half open at ambient temp. Then apply battery voltage across the terminals - the shutter should fully close (takes several minutes).
Check resistance across the terminals - 70 - 80ohms at 20C
Why didn't i think of this! Haha
Ive tested the ohms, its 75 as stated on the plug. The opening isnt quite half way, its more a quarter. And ive had it sitting on the test bench and it has moved. To a closed position. Is there a process to open the valve a bit more to get it to half way? Ive attached a photo of mine at the cold position, you can just make out its on the quarter open position. So for some reason I have no power at the plug through the loom.
Well, it appears that it is pretty much working correctly.
Upon reflection, the symptoms you describe - poor cold start, poor hot idle - don't seem to mesh. I would start looking at dirty injectors. Try a big chunk of injector cleaner in your next tank of fuel.
Have you confirmed that the fuel pressure is ok? Base ignition timing? Water temp sender?
Edited by blind_elk
I'm m not getting power to either of the solenoids, so I'm confident this is the issue.
Both leads on the cold start valve is earthing out. And with a cold engine, I have no power at the AAC valve plug, I did momentarily have some yesterday.
I had the injectors cleaned, fuel is at 50psi, not sure how to test ignition timing.
I'm going to swap ecus and see if that has anything to do with it.
Don't do this. If there is a fault in the wiring that has damaged the relevant circuit in the ECU, then swaptronics is a good way to kill another ECU.**
Instead, why not look into the health of the loom? Point to point check the wiring with a multi-meter. Use the wiring diagrams in the manual to show you what you should be looking for and where.
** Granted, the power for this valve does not come directly out of the ECU, so the risk to your spare ECU in this circumstance is not high. I'm just making a point that you need to think about what you're doing, instead of risking spare parts. Swaptronics is bad practice.
Where do I find this wiring manual? Is it a file on the website?
Air Reg / AAC problems have to be unrelated.
AAC is powered by the ECU relay, and the ECU switches to earth thru pin 4.
Edited by blind_elk
AAC is powered by the ECU relay, and the ECU switches to earth thru pins 4 and 60.
I'm waiting for a new AAC valve, the cold start is working on the test bench. And it turns out when you crank the motor thats when the fuel pump relay kicks in, and you get power to those two plugs.. Durr..
So, the solenoid on the AAC is cactus, so that explains why that wont work, and I believe the cold start may have been just jammed etc. I pulled it apart, hit it with electrical cleaner, and I'm m currently cycling it on the test bench atm, and it seems to be operating.
When I get the new AAC valve, I can continue this adventure, and give progress updates.
Thanks for the help/brainstorming so far everyone!
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
