Curious to know what others think of this data point, this is supposed to be a more modern twin turbo setup for the RB26 vs a GTX3582:
"More info Twins vs Single. 4WD mustang dyno, 92 octane, similar weather condtions, Step 2 V-Cam, 272 exhaust cam on both, both running metal cats.
Blue run are the DR500 twins
Orange run is GTX 35/82
Again this is just more info for everyone. Each of you will have your own opinions on what setup is better. Its coming to my attention that when we post up data, that we have collected, and speak highly of our results its because we are in love with what we do! Its unfortunate that it has come across as being competetive and that is not our intent. The information is there for you to use, only if it applies to what you want to accomplish with your GTR.
And yes we have watched the Motive video."
Link:
Looks like the turbos are made by Spectrum Motorsports in 42R configuration: https://www.spectrummotorsportssolutions.com/products/r32-r33-r34-rb26-smr600
https://www.sau.com.au/forums/topic/480785-revisiting-single-vs-twins/
It's also a shame it's a shop comparing their turbos to others..........
Based on this post the extra 5psi on their twins gained nothing up top https://m.facebook.com/photo.php?fbid=3537861622909572&id=136477713047997&set=a.1284279384934485&refid=13&__tn__=%2B%3Dp...
  • Haha 2
The man is on the hunt for data! Lol
Its very hard to believe unfortunately as my experience driving the whole garden variety of twins on literally every capacity engine has been VERY different to what these guys are pushing
I've been wondering how they've been doing it too, they tend to get results that others don't.
they are selling twins.....
above is my amazing work overlaying the 2 graphs. it seems pretty pointless but i did it!!
I dont think a shop positng photos of a dyno monitor is really providing data. Heaps more info is needed for proper comparison otherwise it is alll just lines on a page.
oh and for that crazy work above i matched the powev figure and x axis (sort of), the boost axis didnt match but doesnt really matter.
DATA!
Next question, is it even a genuine Garrett GTX3582? If it's an US home brew junk or a Dimsum special, it's not going to perform.
Also it's from America, the data is not even worth the server space.
  • Like 2
  • Haha 6
24 minutes ago, GTofuS-T said:
They also posted a twins with V-Cam off and the gtx with V-cam on and they were almost identical... seems fishy... perhaps the gtx cars v-cam if fooked?
Tuned by the marketing team maybe?
  • Like 1
  • Haha 3
1 hour ago, GTofuS-T said:
kind of irrelevant when they're not claiming the twins produce more power, just that the power is on earlier and so more enjoyable to drive
Which is a dumb comparison. A smaller single will do that. Their own data seems to show that their twins are all in a that power, extra 4 or 5 psi made no difference to peak. Give the gtx35 an extra 5 psi and see what happens....
  • Like 1
Not a great comparison point because it's VCAM step 2 vs step 1 but they did have an EFR7163 VCAM step 1 comparison:
"The Black run is a Step 2 V-Cam with a GTX 35/82
The Blue run is a Step 1 V-Cam with a EFR 7163
The Orange run is NON V-Cam with our DR500s
These runs were all done in 4wd with 92 octane in similar weather conditions. I tried to grab an average run from each turbo setup as not be to be misleading."
Also seems like people like the G25-660 for big power which is surprising to me:
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
