I want to make braided coolant lines for my turbo im installing and need to get the correct raceworks hose and fitting.
Im a little confused there's two types of fitting, ones called Teflon and the others called cutter fittings same with different series of braided hoses?
so i don't end up wasting money on stuff that's not going to work im hoping one of you knowledgeable legends can help me out.
This is what I've come up with for the coolant line fittings:
An-6 hose (not sure what series hose i need)
Turbo coolant feed line:
2x metric male m14x1.5 to male flare an6
2x an-6 90 degree hose fitting
Turbo coolant return line:
1x metric male m14x1.5 to male flare an6
1x an-6 90 degree hose fitting
1x an6 straight hose fitting
1x an6 flare to 3/8 (an6) barb fitting
Hopefully that makes sense
Thanks.
https://www.sau.com.au/forums/topic/480794-braided-coolant-lines-for-turbo/
Go with Teflon. Closer to a heat source, the Teflon will cope better.
The critical bit is that you get the appropriate fittings to suit the hose you use, ie. for Speedflow you would use 100 series hose with 100 series fittings, 200 series hose needs 200 series fittings. Teflon hose has a hard plastic inner, it's fittings use an olive that crimps between the fitting shell and the hose body to seal. The 'cutter' style fittings are for a rubber inner so the fittings cut into that rubber hose to seal. If you try to use 100 series fittings with 200 series hose then they won't seal and you'll be able to pull them off by hand, and if you try to use 200 series fittings with 100 series hose then it just won't fit.
  • Like 1
  • Thanks 1
Can't really comment man, you'll need whatever fittings suit the way you are routing the lines. It all sounds like it will work.
I think I used a banjo fitting into the block when I did mine, but I can't remember why. I imagine a straight or angled metric to AN adapter will work just fine too.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
