hi,
ive recently installed a wideband gauge and a turbo timer and since then I have lost the use of my indicator and hazard lights on my c35 laurel( they both don’t work but did previously.
I wired the turbo timer into the key harness going into the barrel & ran the wideband from the power going into my guages, I’m not using the ecu wire just yet so the remaining wires have been taped off..
I have removed the turbo timer and they still don’t work, I have checked all the fuses in the drivers foot well for any breaks and also checked the fuses in the engine bay
any ideas on what’s at fault???
thanks in advance ?
https://www.sau.com.au/forums/topic/480797-indicator-fault-help-needed/
I think I read that it pulls 1.3amp on normal and 2.3amp when heating.. maybe it should be ran directly to the battery?? I thought the power to the guages would be sufficient?? Would that cause the indicator and hazard to stop working?? I don’t have the bung installed yet.
cheers GTSBoy
OK. 2 amps or so shouldn't be enough to cause too much trouble.
On that basis, I am just going to guess that you have dislodged something while futzing about under the dash. You should get the wiring diagram for your car, or a similar car (hint, later R34 or V35 types might be close enough to show you how Nissan were doing things) to see where there should be power, where there should be earth and what sort of plugs might be involved under the dash. Then go probing with a multimeter to find out where the pixies are and where they aren't.
  • Like 1
Cheers man!! Before I left I checked the hazard switch and it was getting 12v, the stick in the steering column works with the lights just not the indicator, I’ll check out the wiring diagrams while I’m away and when i get back in a few week from work I’ll have to get searching with the multimeter as it’s a must fix job ? managed to get the driftworks suspension arms on and did a clean and wax so the weekend wasn’t an entire waste ?7C13A516-B5CD-419A-A376-2C462DD8D171.thumb.jpeg.cdc7d8028724ef7730d86c2ccdc6e3f3.jpeg
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
