Thought I'd make a post for reference for people planning their next build who are going for a stroker or vcam. Theres not enough tangible info on the net when it comes to comparing a stock 26 to a 2.8 vcam with NOTHING else being modified in the process. Its the most apples to apples comparison you will be able to get ;)
Mods before 2.8 vcam:
- 2859r-9s
- Fujitsubo Turbo back exhaust
- Stock Dumps
- Static Bleed valve (non adjustable)
- Fuel stuff - Injectors, pump etc...
- The rest is factory - i.e. intercooler, intake, head, cams, manifolds etc..
- E85 tune on a power fc (yesss i still use fc ? )
Mods After 2.8 Vcam:
Just the Billet 2.8 stroker and Vcam - No porting the heads, no mods to exhaust/intake, just the stroker and vcam with the same bleed valve (unchanged in this dyno run)
  • Like 3
  • Thanks 1
https://www.sau.com.au/forums/topic/480824-rb26-vs-rb28-vcam-dyno-result/
Why would you not get an electronic boost controller or use ECU boost control if going all out on Vcam and a stroker? You spend 15-20K on the engine but not an extra $500 on a good boost controller?
I had an unopened Rb26 with -9's and was making 20.5 psi by 100km/h on pump 98 (3970 rpm on a 34R).
Your boost curve look s like a -5 turbo on a standard 2.6 without E85.
Edited by djvoodoo
  • Like 1
4 hours ago, joshuaho96 said:
VCAM step 1?
Yep Step 1
I probably should of added more context. I'm not a fan of EBCs, as per my tuners recommendations, these arent the best in terms of reliability, better off getting a haltech/motec and control boost using the ECU. We do control the boost using a static bleed valve set to the desired boost pressure. We didnt really want the gate to be forced shut for longer just to make a few extra kw up top as this increased cylinder pressure which as a result puts the car in a medium risk category.
Was your car tuned on 5th gear or 4th? I have driven multiple cars with similar setups (differences being -5s, GTX -5s and my -9s), all VCam, 98 and e85 builds. I can tell you now that this car was the most responsive out of the lot, though tapered off on the top end. I should also add, after going with a free flowing exhaust, the car held boost for longer with no change in boost controller or boost.
Edit: Just did a quick calculation: Yours would have been run in 4th
4th Gear @100kph is around 3790rpm on an 18inch wheel 275/35/18
5th Gear @100 kph is around 2900 rpm
Seeing as it hit 20psi around 117kph 5th gear, its coming on full at 3380rpm.
Edited by Deza3000
  • Like 1
30 minutes ago, Ben C34 said:
Being unsure of ebc's reliability is a new one!
Reliability may be the wrong word.. I meant reliability and longevity of the motor. Given the application, it provided no benefit switching to an EBC.  Its still a street car. I'd rather save up and go flex and have a Motec control boost and maybe the VCam as well.
Edited by Deza3000
Benefit of a quality ebc or ecu boost control is preventing wastegate creep as most wastegates will start opening before target is reached. There can be a noticable difference as wastegate will not open before that target is reached especially on external gates with adding pressure to the top port.
  • Like 1
Any chance of getting the same graph with RPM ?
Thanks for sharing. Lots of peoples opinions on this topic but as you say little back to back data without other changes.
I am also with you on the bleed valve, used one for 12 years on one setup. Works great.
Had some really mixed results with ebc over years. Now using ECU on another setup and its good but not a game changer.
  • Like 2
2 hours ago, Deza3000 said:
Yep Step 1
But it's not hitting 20 psi at 117. Your graph shows more like 18 psi. 20psi prob happens another 150 rpm later, and considering it's in 5th there is more load on the motor.
Im guessing your wastegates on -9's are 1bar adjustable actuators. Why not just wind in some preload into them?
Edited by djvoodoo
Yea I do agree with you, however wastegate creep is a result of excess cylinder pressure, by product of insufficient flow on the exhaust housing.
In this setup, my -9s arent particularly big turbos, forcing the wastegate shut for longer can almost double cylinder pressure up top as exhaust gasses arent able to exit quick enough. -5 turbos with a Bleed valve hold boost all the way through without having to force the wastegate shut with an ebc. That being said, Ill send through another dyno sheet of my car after switching from a twin pipe exhaust to a straight through, ended up holding more boost uptop.
As you said, EBC probably benefits more with external gates and big 600kw power builds. Ultimately rather control boost via a good ECU.
This is all my opinion, i guess some setup has worked better for others.
Ill see if I can! :)
Not a problem! Glad I could help.
So have I, had plenty of discussions about EBC, most recommend ECU controlled or just a bleed valve
5 minutes ago, djvoodoo said:
But it's not hitting 20 psi at 117. Your graph shows more like 18 psi. 20psi prob happens another 1-200rpm later, and considering it's in 5th there is more load on the motor.
Yea they are the dodgy 1 bar actuators garret gives for free. Will look into it! Im all for more response!
Sorry bro, i just don't really understand the reasoning to spend 5-6K on Vcam and a 2.8 stroker, only to use a $30 bleed valve and a Power FC.
You could get much more better results by doing it right - Halaltech/ Motoec/ Link -Whatever and ECU boost control
  • Like 2
Nahh i understand where you're coming from! Long story short, oil pump died and i had to build a motor. I had limited funds and so i just purely stuck to the 2 upgrades that would make the most difference. I only got the Vcam cause i got it for cheap, 3.9k including shipping and import tax so i jumped on it. Racepace installed/fitted the vcam at no extra cost, My Crank was damaged so I went 2.8. I also spent ecu money on preventative maintenance stuff so 9l Baffled circuit sump, Nitto Oil pump.
It was snow balling when i started adding bolt ons, i.e. more boost means needed to do fuel system so another 5k, needed a new front mount as mine was still stock and hit its limit +3k, dumps HPI +700, Haltech + Trigger kit 2k+, if i went haltech id go flex, another 300 etc... Its money i didnt have.
Edited by Deza3000
Lolz... my 12 year old setup still runs powerfc too !
Works great, runs 9's on stock engine with metal HG and studs.
I put a link in it, made zero difference .....  except my tuner was happier.
Back to the powerfc now though for general duties and link is in street car.
djvoodoo, show me a back to back graph where an ecu makes more power swapping from powerfc ?
Data , facts and such.
  • Like 4
Not about power mate. It's about reliability and tuning resolution. Tell me a Power FC that does inbuilt Knock control and can retard timing etc or can put a car in safe mode if a certain limit is reached.
Show me a Power FC that can do motorsport launch control or add multiple external inputs such as additional engine protection sensors, Wideband sensors, CAN Bus displays etc.
All the Power FC does is "blink" the engine warning light...
  • Like 1
 Cool, no argument there, the extra feature set is nice.
You just suggested he would get a better result.  The only thing in the list above that could do that really is the tuning resolution, which makes a very small difference on a simple engine, my opinion ... not fact
12 years, 100s of drag passes, lots of events, stock motor from 1990 challenges your reliability statement a bit :)
To be fair to you i do have a dash with logging, warning etc.
  • Like 1
My better result reference was more around proper boost control, but i mean - He's built a 2.8 Stroked RB26 with Vcam on an R34 GTR.. Go the ECU with the safety features that saves engines man.
I am just a bit cautious around the hype.  These Nissans been making good power for a long time on some pretty basic ecus. Seems you get crapped on if you don't drop $4k on an ECU and all the setup.  In some ways I regret doing it, its money that could have gone into other area's.  I don't have flex or launch setup yet, maybe when i do I'll see more value from it.
  • Like 3
This^^^ Hence why I emphasised the "yes I still used fc"
Ill admit the features are nice, will do an ECU upgrade when the time comes. As stated before, I budgeted towards preventing oiling issues rather than an ecu.  The % of GTRs that have died from oiling issues is far greater than those with basic ECUs with limited safety.
I've had my Haltech engine protection kick in twice now. Once during a drift event when I had a lean out. Probably saved the motor.
Another time when my stupidity resulted in me having the wastegate perma-closed. Having infinity boost most certainly would have done some damage. The engine protection kicking in amazingly well and the boost spike only hit about 22ish psi with no harm done.
Yeah I love my Haltech. I think it is money well spent.
Sometimes having an ECU is like insurance - if you never make a claim it's money wasted right? But when it saves your ass again and again, it really feels priceless.
  • Like 3
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
