Hey people, I was doing my brake pads on my 33 today, to only reach the rear brakes and have 1 slider bolt snap on me on the rear left side and another one seized to the hell on the rear right side.
Im after neither a new calliper mounting bracket for the rear left, an entire complete bracket and calliper for the rear left or replacement slider bolts.
As this is my daily driver, I cannot make it to work till I’ve fixed the issue. So just reaching out here for some help. As I don’t have a lot of time or funds to go with a turbo brake conversion right now. Plus if anyone has any ideas on other Skyline callipers that will go straight on my 33 GTS25, this would be great.
Apologies if this has been covered already, but in a pickle and really need help to get this sorted. I’m based in Melbourne
Cheers
Edited by RIPPA33
Added info
https://www.sau.com.au/forums/topic/480834-r33-gts25-brakes/
Hi mate, I have a good pair of R33 GTS25 rear calipers that would solve your problem.
I have just cracked each of the slide bolts on both calipers to confirm that they will come apart easily.
I will send you a PM with pictures.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
