Good evening everybody! My name is Jesse and I’m the proud new owner of a 95 Skyline GTS25T! This is actually my first foray into RHD territory. I’ve always been a 90’s Honda guy at heart; I’ve owned many good (and bad) Civics and Preludes over the years. I’ve also got a C5Z06 Corvette with “a little” work done. I’ve always been in love with Skylines and jumped at the chance to own a piece of Japanese automotive history. I’ve had this Skyline for a few weeks now and so far, I love it. She only has an HKS intake and an APEXi catback, full exterior LED conversion, but otherwise stock. Right now I’m just working on the usual maintenance stuff and soon I hope to get started with a mild build. I look forward to learning more about this car and its limits! Thanks!
  • Like 5
Thanks! It looks like it was painted maybe a few years ago, but has one little spot of rust where the front bumper meets the drivers fender, easily repairable. I do some car detailing as a side gig, so I’ve got plans to try out a paint correction and ceramic coating. ??
I don’t have too many photos as of right now... but here are a couple more...
”Hey buddy, you’re sittin on the wrong side!” ?
First “mod” was replacing the leaky OEM radiator with a Mishimoto unit. I guess this car sat for months before being shipped here, and I’ve been driving it everywhere on 95+ degree days so it was bound to pop!
Edited by LiteraCola
  • Like 1
6 minutes ago, Duncan said:
looks like the correct side to me, and good score on the light up rear panel.
But you really need some wider wheels on it :)
Wait, that’s supposed to light up??? Mine does not.
Yes, I’m well aware the wheels are trash. Im working on getting the Jap stereo out of there and then I’ll be getting the wheels and tires straight!
It's a pretty rare factory option. I've been trying to buy one but for what they cost ($1000+ USD) I'm just going to make my own.
20 minutes ago, joshuaho96 said:
Be very careful with those Mishimoto radiators, they're garbage.
This. I came here to say the same. Car is quite likely to run hot due to the crappy rad. Keep $500 on hand for a Fenix, or better, for when you can no longer stand it.
Could you guys be more specific? What about them is garbage?
I mean, it’s already in the car so I’m committed. I’ll keep an eye on it, like I normally do anyways. I’m used to driving older cars so I pay close attention to any weird noises, feelings, etc.
I’ve also been in the car game long enough to know that no matter what you buy (car or parts), there’s always someone that says it’s garbage.
If it fails I’ll fix it haha
  • Like 1
Just keep a close eye on the coolant temps, if it spikes over boiling coast to a stop immediately and blast the heater, the Mishimotos are notorious for causing overheating.
I'll do that. Thanks for the heads up! Luckily, the high temps have finally left (if only for a week or so). I don't daily this car; I've got a 98 EK Hatch for that). The Skyline just sits in the garage with the other toys haha. Speaking of toys...
  • Like 4
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
