Have you checked everything on the rack ?
Like the mounting bushes ? hint hint (search) !
Rack ends ?
As GTSBoy stated get underneath while its on stands and get a friend to turn the rack back and forth, lock to lock, and see if there is anything unusual.
What I ment by have it on hand, I ment that I know a guy that sells it. But I dont want to travel 3 hours and then find out it doesnt fit. No need to be rude.
I have checked the rack, thats why I need to replace it. Jesus... This is why I hate using forums, people just cant f*cking answere the question that was asked!..
Hahaha good job. No one ever says on hand but somehow that means 3 hrs away.
This is why I hate using forums, people just cant f*cking provide acurate info when they ask their question and expect others to read their mind
10 hours ago, E.Winjum said:
Hi,
Seems like the rack in my R33 Gtst is toast, and I have an rack from R34 Gtt on hand. Are they the same? Will it fit bolt on?
Dont know you will get an answer as most people use the same rack as their car model is....i assume. I would suggest check amamaya.com for example, see if they have the same or interchangeable part number.
 случайные русские слова
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
