Why are all VR38's with aftermarket turbos still twin turbo when everyone in the RB and 2JZ scene converts their cars to big single turbos? does the V6 configuration make twin turbos more effective when it comes to top end power vs responsiveness? I noticed that its not just drag guys keeping it twin turbo but also Chris Forsberg in his formula d VR38 powered 370Z and time attack cars.
It's a practicality thing. With an I6 it's not that hard to have a single turbo, it actually reduces the amount of intake piping you have. With a V6 unless you want to do a hot V setup and completely re-engineer the engine + transmission a single turbo would have a ridiculous amount of exhaust piping to get to the turbine, like so:
Or you can have two parallel turbos and it looks like this:
  • Like 4
Put it this way, putting twin turbos on an inline 6 is stupid and putting a single turbo on a V6 is stupid.
Also comes down to practicality.
To make twins work on an inline properly you would want twin plenums, twin ICs, twin throttles so there are issues with shuffling, flow disturbances, etc. No-one has ever really attempted that hence all twin setups on RBs and 1/2JZ all suck balls. Its like trying to put two cocks in one bum.
  • Like 2
  • Haha 6
Question
Why is it then that some aftermarket turbo kits for the LS have the turbo only being feed by the one bank?
Yes, the good ones have the both banks merge, but I have seen some big Hp cars running only of 1 bank.
Meh
20 minutes ago, mlr said:
Question
Meh
You sure about that? typically only one new manifold is required and the standard driver side manifold is reused. So when looking at a kit you may be misled thi king only one bank feeds it, but that would suck balls and I have never seen an ls kit like that.
the cross over pipe typically runs ender engine between belhousing and block then up to join passenger side bank.
  • Thanks 1
36 minutes ago, GTSBoy said:
Running a V engine with only 1 bank powering the turbine would be daft. Massively different tunes required for each bank, to account for the massive backpressure on the one with turbine.
Did more googling
The Saab 9-5 3.0t did
It made about 200hp with 3.5 lb.
Even die hard Saab fanboys hated the engine
Sounds like a SR20 designed by NASA
So there you go, you can, and they did, but they shouldn't have, because it is shit.
  • Like 1
  • Confused 2
On 01/08/2020 at 9:59 PM, WR33KD said:
Once he is done braking records it will be put back to gt3 class and be used as a circuit car.
What records is it going to break?   Aside from creating "new" records I am pretty sure it can only really shoot for "pro mod" type times, or possibly an outright AWD record.  I doubt very much any of the GTR record lists/holders will consider it a valid entry.
In regards to the main question, I think the main points are covered - twins are more practical and logical on a V6 and a single is more logical on a straight 6.   I got the impression the STHitec 4WD funny car went single partly as a point of difference as opposed to specifically for performance reasons.
Yeah ST Hitec in NZ have a Vr38 that is above.
It has now removed the Garrett turbo and will be running a single Giant precision turbo.
Only been out for shake downs but is already Australasia's fastest R35 running 7's at 180mph+.
Edited by Stixbnr32
Only been out for shake downs but is already Australasia's fastest R35 running low 7's at 180mph+.
Pretty sure it ran 7.6, and while I love the car and it should go VERY fast, but it's not an R35 - it should not be compared with the likes of SIN35 which is actually an R35 GTR... not a tube frame chassis.
Will be interesting to see how it goes, though - but apples vs oranges.
  • Like 1
5 hours ago, WR33KD said:
Doesn’t really matter the American scene will just make a new category as it’s seems that the 35 chassis has 15 different groups that you can run in to hold a record.
as does every other GT-R created by the Aussie scene
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
