Hey everyone, I was wondering if someone could please point me in the direction of where I can purchase a reputable OEM R33 GTR gearbox rebuild kit? At the moment I'm still shopping around for an AWD gearbox, however I'd like to get a better idea expense wise for the cost of the rebuild before jumping at anything. I have been looking at this kit: https://www.ebay.com.au/itm/Complete-Gearbox-Rebuild-Kit-inc-Synchros-For-R33-GTR-Skyline-RB26DETT/153515049211?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D1f3399f954174a4b8cf4d1166092d1a3%26pid%3D100675%26rk%3D2%26rkt%3D15%26mehot%3Dnone%26sd%3D283966302339%26itm%3D153515049211%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A2d1df879-d481-11ea-a68c-0e4baf4fb02f|parentrq%3Aada5b9541730a6e67f538151ffdcd7f4|iid%3A1
Sold by a business in the UK called Conceptua Tuning that as far as I know have their own brand of OEM parts "Kenjutsu Racing Lab" although I do have some slight scepticism, because I'm unable to find any feedback in regards to their rebuild kits.
I'd like to just state ahead of time that I don't plan on purchasing an aftermarket gearset for the time being, as I'm only in the early stages of my RB & GTR driveline swapped Datsun 260Z project.
Any advice would be appreciated.
Don't know about that kit specifically but after buying a 2nd hand box, rebuild kit and labour costs, it may not make economical sense considering new gearboxes are around 3000 - 3500 aud. There is also a lot of parts in a 2nd hand box that may be worn and not incuded in that rebuild kit either. Unless you know what you're doing and rebuilding it yourself, probably not worth the hassle and uncertainty.
That company has been around a while and as far as i know theyre not shit...but i pieced together oem nissan stuff for a little less than their kit. Although was a bit of dicking around to do.
As above though, you will likely find things like worn couplers/gear teeth once the box is apart. Going whole box brand new would be good idea if you have the extra $$
I was going to reply when you first posted this as there is no real "complete" rebuild kit for a gearbox. There is way too much stuff going on for that. You really need to know what you are looking for to repair them, or you take it to a professional. As Hardsteppa mentioned gears on the main shaft are frequently rooted. We just did the old man's GTR box last month and 1st and 2nd were fked. Have a look at the sides of the gear selector section, they should look like arrow heads, unlike these. Also if there is selector teeth completely missing and your drain plug or looks like this, things are bad. New synchro noted on left, one on right stuffed.
IMG_20200620_153727_5.thumb.jpg.c40692e51fa361aa3f2793b04e0dbcc7.jpgIMG_20200624_162758_3.thumb.jpg.9e3fec13796dfc9efe718ab0b9cb3ecd.jpgIMG_20200620_152508_8.thumb.jpg.430a846425aa1ec71a94c53d6868b1e8.jpg
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
