Hey everyone,
I've got an R34 GTT manual turbo from an auction. The goal is to get it road registered in WA but I've ran into some issues and I need some help. I took it for a test drive today and the following happened:
  • All 4 wheels/brakes siezed after driving approx 3km  with no issues and an idle warm up.
  • Smelt burning and saw smoke coming from engine bay, passenger side, but no drastic change in temp on gauges. never happened when idle testing.
  • Idling poorly after driving
Things that I know need to be fixed on the car prior to this happening:
  • No immobilizer and a lot of loose wiring around the column (pictured)
  • Fans and AC don't blow out
  • Needs wheel allignment
  • Needs new clutch, struggles going into gears etc.
  • Needs new gearbox oil
The plan was to get the immobilizer installed tomorrow but it now has to go to a mechanic to get these new issues fixed. I would be grateful for any ideas and advice.
https://www.sau.com.au/forums/topic/480878-r34-gtt-project-car-need-help/
Immobiliser is the last thing you need to do.
Brake master cylinder sounds like it's stuffed and needs rebuild. Smell is Probably an oil leak onto the exhaust.
Probably best to check compression and leak down and inspect turbo as it may have blown oil seal(burning oil smell)
Car looks/sounds to be a stolen recovered. If not mechanically minded will be a long expensive problem.
fortunately the brakes locking issue has been resolved. The plug that controls when the brake lights are on/off wasn't adjusted properly and it was causing the brakes to lock.
The mystery of smoke coming from the engine hasn't been solved yet, but i'll update as I figure it out. could've been the clutch, brakes locking or an oil leak but right now I'm busy double checking the brake system. Will figure it out through the process of elimination considering that the clutch needs to be changed and I've just redone all the brakes.
I hope you didn't pay someone to come to that conclusion...
Nah didn't pay anyone, i'm trying to resort to outsourcing jobs as a final resort. master cylinder is fine and all brakes are brand new. the plug was pushed in too far causing the brakes to constantly be pumped and on which must've been f**king with the vacuum pump for the brakes when driving by not letting them disengage. Never noticed it before because I had never driven it, but now the wheels aren't locked and can be pushed, and rolls forward/backward when riding whats left of the clutch. I'll keep posting as I clear these things out because this car has been full of really wild mods that could've only been done by crackheads, such as LED's spread through the car direct wired to the ignition barrel being constantly powered even when the cars off. I'm sure it'd make a good read.
 The brakes on Skylines are 100% mechanical. The electrics don't affect how the brakes function. You could hardwire that switch and it wouldn't do anything but turn your brake lights on permanently.
Unless you mean that the stopper was wound so far in that it prevented the brake pedal from coming all the way up? But I can't see how this would happen, then end of the switch is spring loaded and has a good 10-15mm of travel in it, while there is only maybe 5-10mm of thread behind the nut. Even if that was wound all the way in, it could maybe prevent about 1mm of travel (I think even that is unlikely though) and that is no where near enough to jam the brakes on. All it would do is cause your brake lights to not come on when you start braking.
thread was screwed all the way on and it was pushing the brake itself in about 20mm. I'm yet to take it on a longer test drive but just around my street it went well and the wheels are no longer locked when the car is idle which is good. i'll update after another longer test drive but for now I'm trying to source a new clutch.
  • Like 1
  • 3 weeks later...
Update for those interested - I was replacing all the brake pads and saw that the were done incorrectly. plates used to hold the pads were on the wrong way and were grinding on the rotors. pins were also put in incorrectly. The car no longer smokes and the brakes aren't locked.
Next on the list is a clutch replacement, immobilizer and a handful of really expensive plastic parts (eg; wheel arch covers) to get it registered.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
