I was wondering if anyone here had any experience with JUN drop in cams?
im looking at the 264/272 9.7mm lift drop ins because someone local is selling them for a decent price. How do they compare to their HKS 8.7mm lift counterparts?
Edited by KN6_GTR
Typo
https://www.sau.com.au/forums/topic/480889-jun-vs-hks-cams/
HKS cams have always seemed completely bizarre to me when I looked into it. If you get their step 1 VCAM going to their smallest cam means the exhaust duration is higher than the intake. They also limit themselves to 8.7mm lift for seemingly no reason, you can go to 9.1mm lift on the cam without clearancing the head or using a smaller base circle cam.
https://www.sau.com.au/forums/topic/480889-jun-vs-hks-cams/#findComment-7937506
You sure they are drop in ? I have some Camtech RB26 cams for sale now. They are 272 at 9.7mm and they are not usable without relieving the head.
https://www.sau.com.au/forums/topic/480889-jun-vs-hks-cams/#findComment-7937538
https://www.junauto.co.jp/products/camshaft/rb26.en.html
I'm guessing the base circle is 30mm instead of 32mm. I don't know that it's wise though, it's explicitly said that it isn't a bolt-on cam.
https://www.sau.com.au/forums/topic/480889-jun-vs-hks-cams/#findComment-7937539
Their website says they are. I was wondering the same thing. I was under the impression that anything above 9.5 needed machining
https://www.sau.com.au/forums/topic/480889-jun-vs-hks-cams/#findComment-7937553
What isn't wise ? Using a non drop in camshaft ? Clearancing the head is not such a big deal.
Their cams are stupid anyway having so many base circle variations - completely unnecessary, causing custom lifter or retainer thickness changes. No mention of ramp rate duration at 50 thou or lobe separation angles either, so their specs are a bit ambiguous.
Their website doesn't list them in the "bolt in" option, but also doesn't mention anything special in the notes either about anything. The Camtech 260deg 9.5mm as big of lift I know of that is a confirmed bolt in, no machining. That said, I reckon even some heads would need slight relieving with them, as the RB26 head is not exactly cast to 0.1mm sort of tolerances.
Probably should just stick to Kelfords or Camtech, as you know exactly what you're getting and their local.
https://www.sau.com.au/forums/topic/480889-jun-vs-hks-cams/#findComment-7937559
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
