Hello everyone,
Please dont murder me but Can you run a water meth kit on a stock r34 GTT ECU?
I have been considering doing this for the reduced chances of detonation, lower intake temps, and the cleaner combustion.
Some one told me that you need to tune ecu's fuel mapping in order to gain the power benefits but he also mentioned that even with out a tune its still beneficial to run and cant do no harm.
Anyone have a similar experience? is it safe?
Yes but you won't gain anything if you can't add in timing, so in some ways pointless exercise.
If you were to run a Nistune you could use the compensation tables to add timing and lean up your mixture as you ramp in your WMI using the flex input.
  • Like 1
Do you need it?
Is your car currently pulling timing?
I've seen it setup on a stockish car before, triggered by RPM, the only difference I noticed was he had to keep filling the tank with a 50/50 mix.
Tuning for meth needs alot of fail safes.
GTSBoy just posted, so yeah, what he said.
Needs more LS
If you run it untuned you're going to be limited in how much water you can inject. If you add methanol you're going to run even richer than the already rich stock map.
Nostrum energy is the only company that seems to be working on how to make it work properly but I don't think they're going to make something useful for RBs any time soon. I would just run E85, I figure at low boost with decent IATs you can lean it out some with the RB's prehistoric 8.5 CR, or enrich a bit when IATs spike and get the same benefits as water injection with a lot less pain.
not on a stock ECU
45 minutes ago, GTofuS-T said:
not on a stock ECU
Yeah, you need a Nistune or standalone to do it but I don't think untuned water injection is very good either.
If OP wants to run water injection on the stock ECU, my advice is put a very small nozzle just after the intercooler and only activate when IATs suggest heat soak and only inject pure distilled water. If you inject post-IC you don't want large quantities of liquid water making it to the plenum.
If AEM have an electronic tuning/metering kit then it could work ok-ish but in a limited capacity......because you rely on its 'brains' to manage the WMI.
ie I have a Snow performance SIII kit that has its own control module, lets you input IDC and boost triggers and then a sliding scale for when the WMI is triggered and by how much, then at what trigger/s it reaches full flow.
eg I use 12psi and AND/OR 50% injector duty cycle to start injection at 40% flow and then 16psi and 85% IDC for full flow.
You would also need a knock sensor and digital display to check operation.
But to be honest, a nistune or haltech would be better.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
