This is a noob question, but I am looking to get rid of the stock twins on my bnr32 and go single turbo.
The car is mostly a street car and sound is important for me since it's a big part of the driving experience.
I've watched a lot of videos of different setups, I've noticed not all single turbo setups have the exhaust sound I'm looking for and I really love the sound RB26s with T78 or T04z turbos, but I don't need that much power and I want something more modern and efficient. I'm looking to make between 500-600whp.
Can I get the same exhaust sound from cars with those turbos with something for modern like a GTX or G series turbo?
Does the actual turbo influence the exhaust sound much or is it mostly the manifold design?
Does twin scroll influence the exhaust sound a lot?
Any help would be appreciated.
Vids of the sound I'm looking for:
https://www.sau.com.au/forums/topic/480937-rb26-turbo-setup-sound/
Whether or not it is external gate and whether or not the gate is plumbed back in would have to be the biggest contributor to the noise.
Beyond that I can't help you. As I would be 100% oriented in the other direction from your priorities. How it works matters >> than how it sounds.
I think some of the big turbo cars have 3.2L with front facing manifolds to fit the turbo as it doesn't sit between the strut tower.  This effects sound dramatically.  Also the TI exhausts seem to have a certain note.
As above go with what works and get a good fab guy.
Yeah I’m definitely not a fan of the screamer pipe sound.
I’d like to have performance and sound
The other thing to keep in mind is, how something sounds on youtube is not necessarily how something sounds in real life.  Also, what you are listening to said youtube on will have an effect on it as well... If you can't listen to it in person, I wouldn't put much value on a youtube clip.
  • Like 1
There are so many other things that are going to effect that sound, other than the turbo. Your choice of manifold will make a huge difference. A good quality manifold can make an RB26 come to life. The size and design of your exhaust will make a massive difference, hell even the material its made from, ie. Mild steel/stainless steel/titanium - they all sound different. Cam selection, head work, etc. Even intake pipe - I made the exact same turbo on my car sound very different just going from a 3" stainless intake to a 4" carbon fibre intake. And then again going from the 4" carbon to a 4-6" carbon. Huge difference.
Watching a video on YouTube and just picking the same turbo hoping to get the same sound is a good way to find disappointment. And I'm not bagging you out here, because I agree that sound is a massive part of the enjoyment you get from driving a car, especially as a daily. While I would always choose performance over sound, I'll admit to hoping I enjoy the sound when it all comes together. But you gotta be aware that there's a good chance you won't get the sound you're after just by choosing the same turbo - you would have to copy virtually the entire setup.
After watching the videos you posted, I would say the turbo has very little to do with the sound youre wanting. A good quality manifold will get you 75% of the way there. Then speak to a good fabricator that understands how exhaust design influences sound and performance, and get them to build you a full exhaust system. Then pick the rest of the build based on quality and performance.
Yeah I agree, I’m not looking to buy the same turbos I’m looking to achieve a similar sound with a modern more efficient turbo. I think the reason most of the videos I’ve seen with these turbos have the similar sound is because these turbos are often sold in kits including a manifold and downpipe.
Based on what I have seen so far in other people’s setups, it seems like parts of the exhaust with multiple pipes, the manifold (and downpipe if using twins), have much more of an effect on the timbre of the sound than single pipes like a test pipe and catback do.
Any insight into what to look for in a manifold to get this sound? Is it just equal length tubular manifold or is there more to it? I’m assuming twin scroll would also affect it.
I doubt twin scroll effects it significantly- but potentially a little bit.
Any decent performance manifold is going to give you a good sound. 6Boost is a safe bet, FullRace, Sinco, I think even Hypertune make them for 26's these days. Just don't get anything China.
It sounds like what you're after is going to be pretty easy to achieve, you just don't want to go too big with the exhaust and you will want a couple of good straight through mufflers so that you dont get that tinny sort of ring. Any good fabricator is going to know how to build you an exhaust that sounds proper.
  • Like 1
The sound gets better with more power/exhaust flow so all those things affecting flow contribute.
So depending what you choose like Capacity, compression ratio, camshafts, exhaust mani, turbo size, exhaust size, external gate  and muffler choice, the tune and power levels make the sound.
At that level experiment with kakimoto or hks or some aussie combo, the problem i found was that at low engine speed the drone is annoying with big pipes so i made a helmholtz resonator pipe which quitens drone on cruise.. each to there own but works and sounds sweet for me...
Edited by AngryRB
Shouldn’t be ANY drone with ANY size of exhaust with decent mufflers, if there is, it’s time to look at your setup.
A Kakimoto exhaust is a sure way of having something excessively loud and make no grunt for the setup. Best place they’re for is the bin!
Don't listen to any of those suggestions. Steer clear of Jap exhausts. Judging by the Vids you want something on the louder scale?
Muffler size is the key. I have a 3.5" exhaust on my car and its quiet and has absolutely no drone & could be easily daily driven & it gets no attention by the boys in blue
I don’t think muffler or catback have anything to do with the sound I’m after. Yes they make a difference in the final sound, but what specifically I am after (as shown in the videos I posted) is a fundamental change in the timbre of the sound. In my experience catback does not change the timbre much, or at least not in the way that I’m looking for.
It does, and they do. You know that 'timbre' means sound quality, right? Catbacks and mufflers make a massive difference to the sound quality of a performance car.
It means quality in the sense of tone quality (a sin wave would be perfect tone quality with no distortion or other frequencies in the tone). I think a better word for it would be texture or color of the sound. I agree that mufflers and catbacks make a big difference in the sound, but based on the different setups I’ve heard I don’t think the catback portion of the exhaust is responsible for the aspect of the sound I am after.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
