12 minutes ago, Ben C34 said:
This thread sounds  dumb.
You won't get your answer.
I agree I don’t really expect to but it’s worth a shot. It’s hard to describe what I’m looking for.
To give a better example, here’s the same car with 2 different catbacks made from 2 different materials. They sound very different but both still have the part of the sound I’m looking for.
Edited by SnekDoc
So you have contradicted yourself with your reply to my last post lol. I do this for a living (on the side) so I think I'd know. Mufflers & metal make ALL THE DIFFERENCE.
7 hours ago, cachorro said:
It’s the exhaust manifold. Make sure the runners are equal. You’d need something like a greddy trust or HKS manifold
But this is also correct.^^^
T3 open housing vs T4 twin scroll both sound very different.
Nothing I said has been contradicted. I said “I don’t think muffler or catback have anything to do with the sound I’m after”. I posted 2 videos with different exhausts with different materials and while overall sounding different, the part of the sound I’m after is present in both.
That is my instinct but I wasn’t sure. To me it seems similar to how how RBs with twins and an equal length front pipe have a distinct sound at a high RPMs, so I thought it might be related to length of separate exhaust channels before they merge.
  • 6 months later...
I've looked into this topic for years my conclusion was its the rear housing on the turbo, the way its machined gives that menacing tone. Manifolds and camshafts play a small part in sound but not enough to give you the sound you're talking about, I know the exhaust note you're looking for and the only turbos I know of produce that sound are the T51R To4Z T78. All these people getting the T51R mod done on their turbos are wasting their time lol, Nothing modern i've come across yet puts out a menacing tone like those old turbos. I have a .61 To4z if you're interested? You don't need a worked 26 to make it spool.
That’s interesting because the T51r and T04Z have much different rear housings.
I ended up going with a GTIII-4r, the new version of the T04Z. Should be up and running next week so I’ll see how it turns out.
WIth twin turbos, the recipe came down to a;
- higher lift cam on the exhaust side - opens up the flow from the head all the way through the turbos then exhaust.
- equal length front pipe - the clashing of the pulses gave a distinct pitch vs non-equal length
- exhaust steel type, mild/SS/titanium would also give a certain flavour.
I changed the front pipe and cat-back from non-equal to equal-length, and SS to titanium, with barely any noticeable difference.  For my application (twin -9 upgrade) the cams bought the noise to life.
My set up retained a hi-flow cat, and a resonator in the cat-back (Amuse titan R1 extra)
Getting some video done on my car in the coming days ill try remember to come back and post here.
Edited by JGTC
I've got -5 twins with HPI dump-pipes into Tomei Expreme Ti with the stepdown removed for a full 3.5" catless system.
Cams are standard with a ported head and Supertech springs/retainers. It sounds incredible, but very loud.
Also the mafless Greddy suction kit adds plenty of spool induction sound too. Below video of some spirited driving, sound under load, nothing crazy, just mid-range pulls.
At the end of the day, nothing beats a sound of a big sex spec twin scroll single turbo with twin gates or a big single gate.
A twin setup with any exhaust combination will never sound as sexual as a single.
(this is my opinion and to only be used for entertainment purposes, if you are American sorry I hurt your feelings).
  • Like 2
  • Haha 3
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
