RB25DET shortblock for sale, as the new forged motor is in the final stages of being lubed and inserted into the waiting cavity of my engine bay. Make no mistake, this is not your average RB25 shortblock that's been thrashed to death with cracked ringlands and no oil changes for 7 years. No son, this engine was hand built by myself just on 12 months (9000 k's )  back with - full strip down and clean of all parts, OEM pistons cleaned and checked, new ARP rod bolts fitted, cylinders honed and new OEM Nissan piston rings fitted, new OEM rod and mains bearings fitted, new OEM Nissan mains bolts fitted.  I ain't gonna bullshit you and say, I only ever ran stock boost # LIAR!!, of course not, it ran 17 psi with a very healthy maintenance schedule of Castrol edge 10w-40, and not enough ignition timing in the tune for my liking, zero markings on pistons, compression is 157-162 across all cylinders, it runs freakin fantastic.
I had been tossing off whether to keep it as a spare but my garage is crowded enough as it is. This is a bare shortblock so you will need your own everything else, but I can include, stock Nissan oil pump, used (but reusable) ARP head studs, IRIWAY 7 spark plugs, rear main seal/retainer.
Pickup in Brisbane at $600; can post interstate but the current covid ' ting means some delays there...and postage at yo' cost of course.
https://www.sau.com.au/forums/topic/480947-rb25det-rebuilt-oemish-shortblock/
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
