14 hours ago, trel said:
Don't thrash the car and stretch the belt. She'll be right.
can't afford to lol. my only daily driver so i gotta take care of it like a baby, i aint buying another car. though i have been flooring it a few times recently i gotta make sure i dont build that habit haha.
Edited by silviaz
Just thrash it. It won't stretch the belt and break.
Bens right...that guy is a dick....no way could you see the sort of fluctuations he is looking for on a timing belt.  More likely be due to induced feedback in his light cos he is using the same vehicles battery as a power source.
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
