Hi guys my names Dan,
i have had my eye on my friends dad’s datsun 260z 2+2 for about 10 years now and due to some health circumstances he has decided to sell it to me. Its a late 1974 model with l26 and manual box. Currently red but factory green i beleive. Right hand drive too!
my plan is to take l26 and box out and install rb25det engine and 5 speed box. Ive owned many skylines and jdm imports but never a Z so would like to combine the look with the power from new heart!
im an auto electrician by trade and have been for 10 years now. If you have any electrical questions im more than happy to receive pm’s through the forum and ill also try my best to help out with posts asking for help!
good to be here and im sure there will be many questions but from ive seen so far there is an exstensive amount of info here !
Dan
  • Like 3
https://www.sau.com.au/forums/topic/480973-hello-from-south-aus/
Here are some pics of when we bought the car. I was reading through the service history and it only has 66,000kms. we also found an rb25det With gearbox, ecu and loom Out of an r33 skyline for a good price! I got to see it running  the car beforehand and apparently only has 117,000kms but you never know with import cars! Compression test came up quite well sitting at approx 150psi across all 6 (dry)
Edited by Millerman
  • Like 3
You could use a CD009 to get 6spd manual and keep it in the Z family, there are some kits out there to use them with a RB25 and they are well regarded for their ability to handle lots of abuse if you plan on doing a big turbo.
Edited by Agret
Already have 5 speed from the r33, thanks though!
Thanks everyone! Got a hell of a project to get through now!
Dont know if you guys care too much about the datsun side of things but had some spare time over weekend and remove some interior to inspect floor etc for rust. Not much rust at all in the major parts which is good! Was expecting it to all be eaten out haha
still have a lot of work to be done!
I think 90% of people on here would love to do the same thing!
Datsuns and rust is like a dog chasing its tail.... They can look good on the surface and next minute you've drilled out 400 spot welds and there's not much left!
Good luck with it all, especially the rust repairs!  I look forward to seeing it all come together.
If you don't mind me asking what $$ did you pick up the car for? I can't convince myself that I can live with the 2+2 but the 2 seater is insanely priced nowadays and out of reach for me now.
Picked it up for under 10k but i have had to do 2k worth of repairs to one of his other cars also.
i know they look slightly different but suits me perfectly as i have a little boy that loves his cars and would absolutely love to come for a cruise with mum and dad in it once its done!
27 minutes ago, Shoota_77 said:
Sounds like a good deal to me!
Yeah the 2+2 is definitely more functional. The rear of the coupe is basically useless!
Anyway, look forward to seeing what you do with it!
Should look something similar to this when done
  • Like 3
Parts arrival update!
Have received all my bits for rear disc conversion based of an r31 4 stud setup. Have new rda pads and rda slitted + dotted rotors, r31 standard calipers in good nic and custom mounting brackets too suit the conversion!
Bought some new wheels and tyres, we got rota rb-r wheels with bridgestone potenza re003’s.
Raceworks high pressure fuel pump (bosch 044 equivalent)
And the most important part.... engine mounts, gearbox mount and gearbox crossmember!!
Heres a few pics and will upload more shortly!
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
