Hi all,
Purchased an RB26 ATI Super Damper 1000HP version (P/N 917753) to suit R33/34 GTR, however I am running it on my RB20. Quality was amazing however when fitting it it really looks strange. The pulleys and inertia weight sit very far forward leaving a large space behind the hub to the lower crank sprocket. Is this normal? There is no part number on the balancer whatsoever and there is no part number on any of the box or documentation that I received. The TDC markings do line up though and obviously the ID of the hub and keyways are correct as I installed it no worries.
Some pics to help explain (sorry for the bad quality)
Thanks
  • Like 1
https://www.sau.com.au/forums/topic/480992-ati-super-damper-for-rb-engines/
On 8/23/2020 at 1:13 PM, hardsteppa said:
Well its made for rb26 not rb20, so yes normal in that regard. I believe ati say you need to shim the other pulleys to get the belt runners in alignment.
yes but RB20/26 use same lower timing cover. Water pump belt lines up as does alternator, other belts are not used.
On 8/24/2020 at 7:48 PM, tridentt150v said:
Could you machine the back of it down? looks to be room to do it.
Machining it would put it out of alignment, also not machinging a brand new $1000 balancer lol.
It just seems weird having such a large gap between back of balancer and the timing cover. i know hundreds of people on here run these so thought maybe one person could at least verify for me.
are you positive the bolt is all the way home?
personally, i wouldnt be using that balancer. its not even close. spacing shit out can cause another world problems. if it doesnt sit in the same position as the stock balancer i would sell it and purchase a balancer thats meant for a rb20.
i have a 1000hp ati on my rb26, sits where it should all belts line up perfectly. @iruvyouskyrine sorry mate.
Bolt is all the way home 100%
while i agree it doesn't look close in the pics, after comparing to stock balancer it is fine but because they have a lip on the rear you just cant see it. Everything else lines up 100% correctly.
im not sure about rb20s but isnt there suppose to be a shim that goes in front of the timing belt?
also why did you choose the 33/34 pulley and not the 32 one?
i know it 32 balancer is different to 33 as the power steer pump is in a slightly different location (belt alignment wise).
Edited by WantGTR
1 hour ago, iruvyouskyrine said:
No shim using PRP trigger kit
Because it was in stock and the 32 one wasn't
Not using power steering or aircon anyway so belt location on balancer doesn't matter
I was wondering if that was a prp trigger kit lol
I guess what I'm saying is the 32 and 33/34 balancers from ati have diff part numbers. Unless someone can correct me I guess it is because of the spacing of those accessories that the balancers are in fact different. Cant imagine it being much else?
Are you building the motor yourself? What has the work shop said?
What Brett said. It is just the ps/ac belt alignment and rib layouts which are null and void in my case.
Built motors are for suckers, stock all day. Don't let the nissan out.
Ordering new PRP rear belt guide/shim thing, putting that in and then just calling it a day, it should be fine i think it just looks strange.
  • Haha 1
  • 8 months later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
