Hi Guys.
I've got Nismo S-Tunes in my R33 GTR.  I like the ride comfort and handling but at times you can still feel the car could do with something better.
I'm hoping to retain good comfort that the S-Tunes give but get better handling.  Has anyone here on a R33 GTR personally switched from S-Tunes to something else
and can give feedback?
I have read reports from a guy who went from S-Tunes to Ohlins and loved the difference in both handling with still soaking up the bumps well.
Having heard that feedback they will have to be the go, unless there is something locally produced in Australia that can be just as good if not better
Other option is MCA Reds which always appear to get recommended.    Oddly, Nismo and Ohlins have spring rates almost even, while MCA have the front almost double of the rear.
Hell even if the entry level MCA Comfort-Pro's are going to be better than dated Nismo design, I could start with them.
The car also does have 700hp, currently grips perfectly with no wheelspin, I was thinking to go the Ohlins as they aren't too heavy spring rates to help give some squat under power
Any advice appreciated keen to hear your experiences
Cheers.
Edited by RB335
https://www.sau.com.au/forums/topic/480997-r33-gtr-upgrade-from-nismo-s-tune/
Going off spring rates alone to gauge how harsh/firm they are doesn’t tell you much at all. You have valving and fluid used also to consider.
The springs in my current setup are 15 mm front/9 mm rear and are much better at soaking up a bad road than a set of “softer BC’s” (which feel like you have railway sleepers as suspension) and even Nismo S tunes.
You get what you pay for here and a $1099 set isn’t worth the box they come in. Might be 36,000 way adjustable but it’s hard, hard, hard, harder and hardest.
Bilstien PSS9’s and the Ohlin DFV’s are probably a good place to start or as you have already said, the guys at MCA.
FWIW, I’ve had stock, Nismo S tunes, Nismo R tunes and the current setup which is Modified PSS9’s.
  • Like 1
Do you have standard sway bars? If you do, and you're currently happy with the Nismo's, upgrade the sway bars first before looking at different shocks. They'll make the car more planted, especially during spirited driving, and if you get adjustable ones, you can tune the cars handling characteristics. How's the rest of the steering/suspension set-up/condition? Tyres etc. Must be okay if it hooks up with high h/p?
Whilst this is all true, it will conflict with MCA's approach, should you go down the path of getting coilovers from them. They are very much more in the "control roll with spring rate" camp rather than "control roll with bars" camp.
I can see the benefits of both approaches. Loss of independence side-to-side from using big bars is a negative. Hasn't stopped me from putting big adjustables on though. But then, mt spring rates are only in the 5kg/mm range.
Yeah, that's what I was trying to hint towards. If the OP is currently happy with his Nismo's, upgraded sway bars might be just the thing he is looking for. Put it this way, it is cheaper and easier to upgrade the sway bars first, than go all out with some new shocks.
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
