Hiya ... I'm swapping a VQ37 into a BMW and am curious about the fuel system design from factory.
I understand its a return-less system with regulator in the tank with the pump set to 51psi. Does this have a vacuum reference running all the way back from the motor / inlet manifold to the regulator or is it set statically ? Is the fuel pump always on or modulated on/off or voltage changed by the ECU ?
In the USDM 370Z / G37 service manuals i can see a line running from engine to regulator in tank but it does not go into what this is.
I'll be looking to convert to a return system (as the BMW is) with filter and regulator in the engine bay but want to know if I need to vacuum reference it or not and if the fuel pump can be wired 'traditionally' so it will be always running via the return system. Will also need to add the fuel temp sensor which is used on the VQ also it seems.
G'day Mate, no Vacuum reference, fuel pump is always on. When using an aftermarket pump, just use the factory fuel pump + wire to switch a relay for pump supply.
Here's a vid on my youtube channel showing setting up fuel return & the fuel pump wiring I did as a part of my TT Build
  • Like 1
Awesome thanks Trevor !! Watched your video and like the look of the CJ kit for regulator implementation without altering the fuel rails so I think this method will suit me very well also.
Did you make the solution yourself or do they provide this as a kit ? This looks like the tap fitting, at that point its hose and fittings + reg I guess !! https://cj-motorsports.com/products/fuel-tap-npt-2-bolt
Yes, I have the full CJM  fuel return Kit, I think this is the fitting here. https://cj-motorsports.com/products/fuel-tap-4-way-2-bolt it gives you fuel in, fuel out to the Rails , by pass to the reg  then back to tank & Gauge Port.
Cheers Mate.
Edited by mycarhasposessedme
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
