Team Raceworx have obtained some great prices on OBX seats.
Full details are on this webpage:
http://www.hgeconsulting.com.au/raceworx/obx.htm
Prices are from $460 per pair which is about half what you would pay elsewhere! With the money you save you can get BRIDE embriodered on them
Please note seats are sold in pairs only, but if 2 ppl agree on the same seat and colour I can organise that.
Also note the seats do not come with rails, you should allow up to about $200 to buy new ones or have your factory rails modified.
Please post interest in this thread.
https://www.sau.com.au/forums/topic/48101-cheap-obx-race-seats-for-sau/
  • Replies 75
Is that per/rail or for the pair?
yeah I should have been cleared, $200 ea.
So if you go fixed back, you could have 2 news seats, installed from about $1k.
The other option is to go halves with someone else who is interested, if anyone just wants one seat post up here and we will try and match it up.
Are they approved for CAMS events etc? (Scuze my ignorance).
Also where would you get the rails from?
Is there any chance of having a look at the seats? (either through another seller or somewhere that may stock them)
Thanks - they look great too!
Yep, they are CAMS legal if mounted correctly, we have used them in NSW circuit racing and Targa Tas.
As for rails, there's a couple of choices.
INASNT has a group buy going for rail, these seats should be able to bolt on. Alternatively I know Powerplay in Drummoyne sell Bride rails which bolt straight in. Third choice would be to get a workshop to have a look at reusing your standard rails.
Having a look at them, I have the Forza in my race car, and we also had a couple of people buy the Daytona. Apart from that we don't have a any of the other models to have a look at.
Yes i do, check my signature.
They are bride copies (From my original bride rails) and they are not just the rails but the whole seat frame with the drivers side belt buckle which bolts directly to the skyline floor plan, then they you just to slight modifications to to bolt the seat down.
Register your interest in my thread as the first few are getting made today so i can finially put my recaros in.
you can get these seats on www.modyourcar.com for a little cheaper...
actually I'll beleive you'll find our prices are cheaper as they include delivery to capital cities. MYC will slug you an extra $15-20 on top for that.....
i see there are r32 rails.. yay thanks!
thanks for the offer SW20 I am actually interested in the carerra but may take you up on that offer just to check the seat out.
Thanks alot all of you guys appreciate the info!!!!
Nozila, the fixed seats can be a pretty firm fit...great for spirited driving but it might be inconvenient day to day...just depends how much you want a good tight seat :rofl:
I'm pretty interested in the cheap (wide) fixed Daytona in black, or the Monaco. Duncan, What is your opinion of the choices I have selected (which are obviously the cheapest) fitting wise?
These guys in Melb have them so I will go take a look if possible. http://www.australianauto.com.au/
Nozila, we have already made our minimum sales so we can continue to offer these prices whenever you order.
Skylinegeoff, Australianauto are the OBX importers, we resell for them and should be a fiar bit cheaper than going direct :P If they have a showroom you should be able to have a look. We have acually only sold fixed back seats to date so I can't really tell you anything more about the monacos. The Daytona I have seen and they are fine, they can be mounted direct to the floor as we have for our race cars on on rails (eg Bride or INASNT's copies). Personally, since you are in Melb I would go for the copies as they are cheaper and you can check them out locally, in Sydney I'd get the Bride originals from Powerplay as they have them in stock atm. Some cars you can modify the stock rails to suit but apparently that's pretty tricky for a skyline:(
Guest
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
