  • Replies 75
wtf is an ork van :confused:
:P
The Bride rails bolt straight into a R32-R34 skyline. From there, the OBX seats bolt onto the top of the rails. The rails have 4 holes, but depending on which OBX seat you choose you may have to drill 2 holes in the rail. They are $295ea from Powerplay.
A cheaper option may be to start with generic style rails from somwhere like race and rally, but if you go that way you will need someone to help you mount the rails to the car. Mounting the seat to the generic rails is the same, 2 holes are OK, 2 you may need to drill.
Hope that helps :D, its pretty sad when the rails cost more than the seats ;) They are still a pretty good deal compared to the $1k + people ask for used Bride seats.....
yeah, thanks Nissan for creating the world's most uneven floorplan....you will definately need at least some custom fabrication if you go generic rails, both for the uneven floor and for the seat belt mount on the drivers side.
The Bride rails or a copy are the easiest option :(
yeah Powerplay have them in stock at $295 which I got the impression was pretty cheap. Its a shame you can't get them made up cheaper :)
  • 3 months later...
well....that very much depends on which ones you go for....
If you take a deep fixed bucket one like the Forza, they are a real pain in the arse to live with....don't buy something like these for a daily driver unless you really know you want them. On the other hand they are superb at holding you in place :P
On the other hand the reclining ones are more open and wider. So, they don't hold you as tightly but they are much easier to live with :D
  • 5 months later...
just measured my hips from point to point with a ruler here at work. about 55 centimetres. man i need a wide seat. duncan when are we gonna meet up next? i gotta try out your seat.
cheers, MARK
cheers, MARK
Hey Duncan, is Mark saying you got a fat arse mate?.....LOL
Ian
haha he is probably right to...for me I looked at the regular/narrow seats and just laughed :P
Anyway, Mark come out to the UAS day I will have the race car there, I have the forzas in it which are the same width.
midnight, unfortunately I can't get further photos than what are on the site....we don't carry any stock to take pics of, thats how we can do them so cheap :D The Forza in blue/black are mostly blue with black highlights (like the yellow/black on the pics).
I did come across some OBX seats at Autobarn, so you might find them there.....just don't pay their prices ;)
Hey negative.....rails are the biggest problem with aftermarket seats :P
The easiest way I've found is getting a set of the Bride rails, they bolt straight in and the OBX seats bolt straight to them.
Hey mate the seat you tried was a Forza, which is the same width (410mm) as the daytona wide. Unfortunately that is as big as they make the fixed back seats.
If it was too tight there are always the recliners, they still have pretty good support but are roomier for the ample gentleman :D
OBX are great seats, these are awesome value, i have two black monaco seats in my 4dr 32 and they are great for all day driving and track use, and best of all they are on the standard r32 rails and are comfortable for the everyday driving. Good luck with the group buy.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
