So, a friend called me to see a GTR with a built RB26 that has been smoking hard under WOT load , it made 480hp, 360tq with the last turbo (precision). on the dyno and they saw smoke coming out of the exhaust housing and then the exhaust pipe.
Before that, they thought the turbos were the problem. new turbos, same thing, precision single turbo, same thing.
So i went to help, checked compression (all good around @ 170psi), did a leak down, found cyl 1 and 4 giving a loss of around 10-12 psi @ 74psi down to 60 and 70psi to 54, other cyls had 2-4psi loss. This is my only clue.
* Checked PCV valve, its fine, plugged it just in case
* Took valve cover hoses off (oil catch can has no crank return nor atmosphere vent, its basically a closed box)
* Oil return seems adecuate, no rough path to the crank
Then, we tested the car, hard wot 1st,2nd and 3rd gear, it only smoked on 3rd gear WOT at high rpms (6500+) and it was a lot of smoke, it blocked the lane behind us. Oil came out of the disconnected valve cover outlets and fell on the turbo and block. As expected. we have to retest with the hoses pointing to the intake side but since they DID see smoke coming out of the tailpipe on the dyno, i can only hope that the PCV being completely closed off could have done something internally with its built pressure on the dyno and burnt oil inside the combustion chamber. I saw some wetness on the pistons from the plug hole, saw no oil or sign of it on the downpipe and exhaust housing.
But being realistic... i fear that something is wrong either on the pistons or valve train area. I thought it was the PCV system because i saw the closed box and wondered about the PCV valve etc.But seeing the compression fine but a bad sign on the leakdown. So this left me curious.
I thought a cracked piston ringland or a bent valve or bad valve seats would show at all RPM ranges, to different degrees, but this engine only did its smoke screen on 3rd gear, WOT, after 6500 rpms. Any ideas? experiences? i cant open this engine for fun as its not mine so im left with the sad state of not knowing for sure.
Edited by Lopin18
https://www.sau.com.au/forums/topic/481013-rb26-smoke-during-3rd-gear-wot-only/
Both hoses from the valve cover go to the oil catch can, PCV valve is joined with one of those valve cover outlets.
The catch can itself has 2 inputs from the valve cover outlets. NO outputs on the catch can, meaning no return to the crankcase, no vented filter, no outlet to the compressor pipping.
So basically pressure just builds up, theres nothing venting or allowing the crankcase pressure to go anywhere (just the PCV valve, which will be closed during boost)
Well that is completely f**ked.
Neat, i was thinking so much i didnt remember that the oil return line from the turbo is another path for pressure to build up. Thanks for the feedback. On monday they will trst the car again to confirm, ill reply back then
in the dyno they noticed the valve covers leaking pressurised air, along with oil, but the valve covers were a bit loose, i can imagine the pressure buildup was enough to cause what they saw...
I don't really understand how such a simple thing can be so misunderstood!
Either block your PCV and vent the rocker covers to atmosphere into a CATCH CAN - with a hole at least 1" in diameter for each hose going into it so pressure can escape, preferably with a filter/s to catch some of the oil jizz
Or keep your PCV valve stock and install a SEALED OIL/AIR SEPARATOR r that goes between the rocker covers and hose into the turbo inlet
They are the only two options that exist for it to work properly
  • Like 1
:D U would be surprised how many people dont take crankcase ventilation into account.
They tested the car today, no more smoke. So hopefully its just working the crankcase ventilation.
Thank you btw, i had missed some concepts including the turbo oil return line.
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
