I checked my atf fluid for my ej20 automatic transmission it seems fine though looks orangish on the paper more yellowish on the dipstick if i remember correctly. No idea the last time it was serviced.
I also had a side question:
1) I notice when i put my car in drive and if i put my foot on the gas straight away it rough shifts, hard to explain but it's like the car hasn't put it self into first gear yet and I'm rushing it into first gear.
2)When I shift gears it shifts fine no problem I just might be imagining things but it seems I feel like when it does shift that the car bumps backwards like im getting pushed back if that makes any sense.
These 2 questions the car has always been like that since I bought it, either it's normal or I've been careful not to make it worse if it is a problem lol.
https://www.sau.com.au/forums/topic/481014-is-it-time-to-change-my-atf/
1 hour ago, silviaz said:
I change the oil and filter every 5000km. Or you referring to something within the transmission
Yeap, trans oil and filter.
Post up model and year mate
  • Like 1
10 hours ago, silviaz said:
2001 impreza ej20. automatic.
Cheap
This "should" be the filter and gasket, you need to check p/n https://www.ebay.com.au/p/18017006797
Find a youtube for what you need to do when filling, you basically refill the transmission, run the car and select each gear a few times, tgen recheck the level.
Rinse and repeat.
With some stands and basic tools it shouldn't take more than an hour.
You probably don't need a full flush, but if you do they are more involved.
Enjoy
A dry fill requires 8.6ltrs of fluid.
If you only drain the pan and replace the filter you won't need that much.
http://www.penriteoil.com.au/product-selector#/recommendations
I would personally just get a 4.5ltr bottle and see where that gets me, if I needed more I would just take the bike or Mrs car to get any extra that I needed.
Don't spill the oil oil, it stains like 10 staining things.
Here was what teh person at the shop gave me they weren't even completely sure lol. So hard to find for this model what it takes i have no idea why.
4 hours ago, silviaz said:
apparently there is an external filter aswell? according to my research their isn't so I'm confused.
External filter is for the high torque box, the WRX, and 3.0 LOLberty use the high torque boxes.
Others to maybe, meh, stick it up on stands and have a look.
https://en.wikipedia.org/wiki/List_of_Subaru_transmissions
Hey mate do you know how much I have to torque the bolts inside the pan and outside the pan? I can't find a manual for this car anywhere.
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
    • No. Go a different colour, and just trim it at an edge line. Even manufacturers do different panels different colours etc.
    • I see no real downsides to ITB's, apart from the initial cost of my drive in drive out lifestyle, the "upsides" is they sound cool and would add lots of smiles I am willing to pay to play for the extra smiles I've spent the morning googling and youtubing the BBR ITB's, a "little" extra power and throttle response, but alot more dort, and really, I'm only really in it for the dort Who knows, after all this money is spent I might even make 150kwatw....LOL
