Hi all,
To preface, I have searched tirelessly, to no avail.
As far as I can tell, RB25 S1, S2 and NEO blocks are identical. The Neo heads are obviously very different. I have an S2 25 head and have found a good deal on a NEO block. I can't seem to find a definitive answer as to whether I can use the Neo block with the S2 head. I'm going fully forged and am looking for confirmation that the Neo block and crank will accept forged non-Neo 8.5:1 pistons and rods and not run into problems with the S2 head. As far as I can tell, this should have the same outcome as an S2 block with the same rods and pistons.
Preemptively, buying a Neo head is a last resort due to my location and freight costs.
Cheers
https://www.sau.com.au/forums/topic/481021-rb25-neo-block-compatibility/
I'm building a forged Neo myself right now, and the different pistons allow for the different cylinder heads, and the relevant compression ratios. Got to run the correct piston to suit the head, if you want the package and known compression ratio to be simple, and easy to tune etc. Blocks should be same.
Do some research on oil gallery restrictors (in the deck of the block) as well, as their configuration depends on the head you're running as well (VCT or non-VCT). Platinum Racing Products has a good diagram on their Insta page explaining this...
I'm not a guru yet, so confirm what i've suggested elsewhere as well. But as far as i can tell, get those couple things right, and you should be sweet.
You did not try very hard at all, over the years this has been discussed many times
If you search Neo block you find many pages, I guess reading through the titles was  too time consuming
Edited by Rusty Nuts
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
