LINK17 Posted August 25, 2020 Share Posted August 25, 2020 Hello All, The above has recently happened to me so I obviously got onto Google. I found a great video by gk tech on how to adjust the handbrake. Before you put your rear on blocks and take the wheels off - check the handbrake cable adjuster attached to the handbrake lever in the centre console. My adjuster nut had worked loose and fell off; I put it back on and set the handbrake. I'm not sure if this is a common problem but it took me 10 minutes instead of 2 hours to fix. Link to comment https://www.sau.com.au/forums/topic/481022-r32-handbrake-fails-after-2-weeks-potential-fix/ Share on other sites More sharing options...
