Hey guys,
My precious rb26 blew its stock turbos on my way home earlier this summer. R33 gt-r 95mod.
I just did a compression test now (cold engine), and got these readings:
Cylinder 1: 155 psi
Cylinder 2: 155 psi
Cylinder 3: 160 psi
Cylinder 4: 145 psi
Cylinder 5: 140 psi
Cylinder 6: 135 psi
Now keep in mind the engine is cold.
I’d like to hear your opinion on these readings?
https://www.sau.com.au/forums/topic/481035-blown-turbos-help/
Sorry but it doesn't look good. When the exhaust wheel lets got at 150,000rpm, ceramic pieces have enough velocity to travel against the exhaust gas, through the open exhaust valve, and scratch the shit out of the cylinder bores. Happened to me when I first got my car, and I guess it has just happened to you.
A borescope could be used through the spark plug hole to inspect the bore for scratches.
If that has occurred, you need engine out bottom end rebuild, with bored out cylinders and oversize pistons. Expensive, but not compared to GTR prices these days....
  • Like 1
Blown turbo doesn't automatically mean his turbine wheel grenaded. Now with that said, the difference you have in compression between cylinders isn't great. Report back on a warm engine.
  • Like 1
Buy this.
https://www.ebay.com.au/itm/8MM-HD-WiFi-Endoscope-Inspection-Camera-Waterproof-for-iPhone-PC-iPad-Samsung-AU/163440076341?_trkparms=ispr%3D1&hash=item260dc9a635:g:ofMAAOSwsPNcGhBL&amdata=enc%3AAQAFAAACcBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkfOCvCjTOBWK8pwriaolq5l3YoyuRM1%252B5hQF96Q9VN70RMc3%252BYWb9Tsc4TGw41eT3TQyUnv930nBOYpCpeC0DLYi7CxMTZyPioOoOXgQasbGPlG6QtpP4pYAS6Fwp8lyvvZts9%252BMI7tKcAxRtSZg3PJaSRXesma1BQe9Y7Kk0x3lSKjtYvm8qvSbcGe6Le3XGCKqKt5N5%252BpmvMtHRRXcSMV7vH6cH2a1pfxad7lFk9REJ%252Fs9T%252FxkpiEeVzDso%252FxydMWoLVe1u58T95RoHmLBtO7UIuxhfvPW3Iwi0mSO1EhyhN%252BoIO%252FymShnXkKaBlgrverdWmmwCbiAxDdOJF9aVLKX3JZUC%252BRtHPIhIDYo9ycOshD%252B5hpeoZWH6aXXeWU%252Fi2T33k3JYi9Ww5oOdwTKLoigaAHGwopMekvh6MThpmeZVA0yFlG7%252FjqbXqMJtd%252FmENiHbwrQXc1QUAnEZr7dGv6vpcB3sHdkcVM67Xnr%252F%252FH3yBsbLHavof5BBTxjSoagT2C2akfcq8wyteFQCNP%252BE8eM2CNqVwN4mUDoYlN5f2Q1WbTtdXKDtkB7V%252BsuNLiZTPLCpyBR%252BubPJeKl1SsS%252FQLpW7nlSkqYn%252B82yIyrazSiJyR4QI%252BZpMZjKEdD8nPgDFbaKcvPK86w2c9Xtx1G4%252FkI6lHclPYp097es4WMhHReOO4KjHTLfLU8wtmotJTjP7q4pHEWo6lXcmHLGEHVVAyK%252BJ5mdYoG%252Fc6nO7DO48l8qMbgdbmxaWLlzkT78ScXaWWCP9FklM%252B8LYCnKMqZUBg%253D%253D%7Ccksum%3A163440076341da5adf177ea64ed6b78adc0d6112fd23%7Campid%3APL_CLK%7Cclp%3A2334524
  • Like 1
Agreed, but the concern is all 3 rear cylinders are well down which matches an issue with the rear turbo affecting cylinders 4-6
  • Like 1
Guys,
As i’m quite new to this, please excuse me if my questions are «stupid».
I thought about doing a compression test with a warm motor. But seeing as there might be a chance i have ceramic dust in my engine, wouldn’t it be damaging (or cause more damage) running the engine till it’s warm?
don't worry about it mate. if that is the issue you won't make it worse warming it up.
back to an earlier question what did you mean when you said the turbos were "blown". potentially an overboost issue could end up with ring land problems on the rear 3 cylinders too, but either way it is the same solution (pull engine and tear it down)
Alright, thanks.
What happened is i did a small pull, probably overboosted and the rear (i assume) turbo said farewell. It cut boost during the pull, and it started coming blue smoke from the exhaust.
Seeing as i intend on keeping her for a while, an engine rebuild wouldn’t be so bad i guess :)
Hello again,
Sorry about the late update, i’ve been busy due to work.
I did another compression test today with the engine warmed up, and i got these results:
Cylinder 1: 168psi
Cylinder 2: 171 psi
Cylinder 3: 170psi
Cylinder 4: 165psi
Cylinder 5: 155psi
Cylinder 6: 158psi
What are your thoughts?
3 hours ago, Oddamannen97 said:
Hello again,
Cylinder 1: 168psi
Cylinder 2: 171 psi
Cylinder 3: 170psi
Cylinder 4: 165psi
Cylinder 5: 155psi
Cylinder 6: 158psi
That looks good to me!
  • Like 1
1 hour ago, Oddamannen97 said:
Alright, thanks. Is it necessary to do a leakdown test as well?
It's a while you're there deal, you might as well to give you a little better insight as to the state of your engine. But nonetheless the numbers look good.
Edited by trel
  • Like 1
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
