Hey guys,
My precious rb26 blew its stock turbos on my way home earlier this summer. R33 gt-r 95mod.
I just did a compression test now (cold engine), and got these readings:
Cylinder 1: 155 psi
Cylinder 2: 155 psi
Cylinder 3: 160 psi
Cylinder 4: 145 psi
Cylinder 5: 140 psi
Cylinder 6: 135 psi
Now keep in mind the engine is cold.
I’d like to hear your opinion on these readings?
https://www.sau.com.au/forums/topic/481035-blown-turbos-help/
Sorry but it doesn't look good. When the exhaust wheel lets got at 150,000rpm, ceramic pieces have enough velocity to travel against the exhaust gas, through the open exhaust valve, and scratch the shit out of the cylinder bores. Happened to me when I first got my car, and I guess it has just happened to you.
A borescope could be used through the spark plug hole to inspect the bore for scratches.
If that has occurred, you need engine out bottom end rebuild, with bored out cylinders and oversize pistons. Expensive, but not compared to GTR prices these days....
  • Like 1
Blown turbo doesn't automatically mean his turbine wheel grenaded. Now with that said, the difference you have in compression between cylinders isn't great. Report back on a warm engine.
  • Like 1
Buy this.
https://www.ebay.com.au/itm/8MM-HD-WiFi-Endoscope-Inspection-Camera-Waterproof-for-iPhone-PC-iPad-Samsung-AU/163440076341?_trkparms=ispr%3D1&hash=item260dc9a635:g:ofMAAOSwsPNcGhBL&amdata=enc%3AAQAFAAACcBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkfOCvCjTOBWK8pwriaolq5l3YoyuRM1%252B5hQF96Q9VN70RMc3%252BYWb9Tsc4TGw41eT3TQyUnv930nBOYpCpeC0DLYi7CxMTZyPioOoOXgQasbGPlG6QtpP4pYAS6Fwp8lyvvZts9%252BMI7tKcAxRtSZg3PJaSRXesma1BQe9Y7Kk0x3lSKjtYvm8qvSbcGe6Le3XGCKqKt5N5%252BpmvMtHRRXcSMV7vH6cH2a1pfxad7lFk9REJ%252Fs9T%252FxkpiEeVzDso%252FxydMWoLVe1u58T95RoHmLBtO7UIuxhfvPW3Iwi0mSO1EhyhN%252BoIO%252FymShnXkKaBlgrverdWmmwCbiAxDdOJF9aVLKX3JZUC%252BRtHPIhIDYo9ycOshD%252B5hpeoZWH6aXXeWU%252Fi2T33k3JYi9Ww5oOdwTKLoigaAHGwopMekvh6MThpmeZVA0yFlG7%252FjqbXqMJtd%252FmENiHbwrQXc1QUAnEZr7dGv6vpcB3sHdkcVM67Xnr%252F%252FH3yBsbLHavof5BBTxjSoagT2C2akfcq8wyteFQCNP%252BE8eM2CNqVwN4mUDoYlN5f2Q1WbTtdXKDtkB7V%252BsuNLiZTPLCpyBR%252BubPJeKl1SsS%252FQLpW7nlSkqYn%252B82yIyrazSiJyR4QI%252BZpMZjKEdD8nPgDFbaKcvPK86w2c9Xtx1G4%252FkI6lHclPYp097es4WMhHReOO4KjHTLfLU8wtmotJTjP7q4pHEWo6lXcmHLGEHVVAyK%252BJ5mdYoG%252Fc6nO7DO48l8qMbgdbmxaWLlzkT78ScXaWWCP9FklM%252B8LYCnKMqZUBg%253D%253D%7Ccksum%3A163440076341da5adf177ea64ed6b78adc0d6112fd23%7Campid%3APL_CLK%7Cclp%3A2334524
  • Like 1
Agreed, but the concern is all 3 rear cylinders are well down which matches an issue with the rear turbo affecting cylinders 4-6
  • Like 1
Guys,
As i’m quite new to this, please excuse me if my questions are «stupid».
I thought about doing a compression test with a warm motor. But seeing as there might be a chance i have ceramic dust in my engine, wouldn’t it be damaging (or cause more damage) running the engine till it’s warm?
don't worry about it mate. if that is the issue you won't make it worse warming it up.
back to an earlier question what did you mean when you said the turbos were "blown". potentially an overboost issue could end up with ring land problems on the rear 3 cylinders too, but either way it is the same solution (pull engine and tear it down)
Alright, thanks.
What happened is i did a small pull, probably overboosted and the rear (i assume) turbo said farewell. It cut boost during the pull, and it started coming blue smoke from the exhaust.
Seeing as i intend on keeping her for a while, an engine rebuild wouldn’t be so bad i guess :)
Hello again,
Sorry about the late update, i’ve been busy due to work.
I did another compression test today with the engine warmed up, and i got these results:
Cylinder 1: 168psi
Cylinder 2: 171 psi
Cylinder 3: 170psi
Cylinder 4: 165psi
Cylinder 5: 155psi
Cylinder 6: 158psi
What are your thoughts?
3 hours ago, Oddamannen97 said:
Hello again,
Cylinder 1: 168psi
Cylinder 2: 171 psi
Cylinder 3: 170psi
Cylinder 4: 165psi
Cylinder 5: 155psi
Cylinder 6: 158psi
That looks good to me!
  • Like 1
1 hour ago, Oddamannen97 said:
Alright, thanks. Is it necessary to do a leakdown test as well?
It's a while you're there deal, you might as well to give you a little better insight as to the state of your engine. But nonetheless the numbers look good.
Edited by trel
  • Like 1
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
