Shed clean out of various R32 GTST Coupe parts when stripping my race car
To many to list individually
Message me if interested
Pick up from Dapto NSW
Happy to ship at buyers expense
Can provide higher res pics of individual items if required
Cheers
Jason
Hi,
I would like to register my interest in;
  • The front window mirror inside panels (the plastic triangles).
  • The front indicators (provided they look pretty schmick - I don't need them if they've got chips/cracks etc.)
  • The air-con controller (provided it's working)
  • The seat belts (provided they're not frayed on the edges and are otherwise working)
  • The door window mechanism (provided it's working)
  • The wastegate actuator (provided it's the stock RB20 10 psi unit and you're happy to keep it separated from the turbo!)
If you come up with a $$ number that you'd like for that lot and an allowance to ship to SA, send me a PM and we can discuss.
cheers
Do you happen to have the seat belt retainers with the release button that the buckle lock into for the front seats?
54 minutes ago, GTSBoy said:
Hi,
cheers
No problems
Ill take some better pics of these items and send to you.
The front window mirror inside panels (the plastic triangles). No problems
The front indicators (provided they look pretty schmick - I don't need them if they've got chips/cracks etc.) Some scratches, and one of the mounting tabs broken on each indicator
The air-con controller (provided it's working) Not 100% sure, was disconnected when I bought the car.
The seat belts (provided they're not frayed on the edges and are otherwise working) No Frays and are working. Still have the passenger front in the car so its only the drivers front and both rear
The door window mechanism (provided it's working)Yes, working Bought to fix my drivers door, but just using passenger side switch to do both windows
The wastegate actuator (provided it's the stock RB20 10 psi unit and you're happy to keep it separated from the turbo!) Actuator is off RB25 turbo. I am now using the RB25 turbo with RB20 actuator
I think so, but didnt find them when doing the clean out. Ill have another look and let you know
  • Thanks 1
3 minutes ago, Jasoncauser said:
No problems
OK. Some changes to my list based on your feedback.
Indicators and wastegate actuator can drop off the list.
Air-con controller is a mystery proposition, so value is low. Still willing to risk it for a low enough price.
Driver's seatbelt is the main one I'd be interested in anyway, so the missing passenger's is OK.
Better pics of mirror panels, air-con controller, belts & window mech happily accepted.
No Problems, Will take some pics tonight.
1 minute ago, DaymoR32 said:
price on the front indicators?
They do have a few scratched and each one has a broken mounting tab.
give me a figure your happy with
Can send better pics if still interested
grab a few more pics and we'll go from there mate :)
That would be awesome if you could. Thanks.
  • 1 month later...
  • 10 months later...
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
    • Can confirm previous shop that built my motor had no fking clue about oil control and caused my motor to shit itself after two track days. Current shop, Birrong Automotive, has managed to build me a motor, not to mention, has also let me tune it myself and it has yet to blow up after 7 track days. Great oiling success, yashimash.
    • It definitely seems like you have no beef, with only digging up a 5 year old post, to comment on an inflammatory item with total insensitivity, and of which had nothing to do with the thread.  Yep, you definitely seem like a great person and your friends and family would be so proud to know of your lovely actions
    • Thanks buddy, so happy to be back! Managed to pickup a Unicorn R34 completely stock and clean. Looking forward to adding some goodies to it and posting one here. I'm shocked that so many forums stopped. If you could find my old profile - I'd love that if its possible. My old account was JET200GT. My email might need to be fixed too. To use this one. I think it was the same though..
