I need to replace the high pressure line from the pump to the transfer case since it's leaking (PN 41706), car was bucking under WOT acceleration and removing the AWD fuse resolved it.
I'm wondering if anyone knows the best way to replace the line without spilling fluid everywhere? Is there a way to fully drain the ATTESA system or do I just unbolt the line and hope I have enough brake kleen to get it all after?
Also, regarding fluid. I've poked around on the forum but haven't seen a solid answer. I can't seem to get my hands on Nissan Power Steering Fluid Special, so I was thinking I would just go for Nissan Matic D since others have had good luck with that, unless someone knows a place that will ship PSFS to Michigan, US?
I included pictures of the leaky line and the diagram I pulled the PN from in case I got the part number wrong.
IMG_20200830_111122.thumb.jpg.58fd7cccea15d64ee673cb0f45e32a60.jpgIMG_20200830_111136.thumb.jpg.3bf3c7fcb6fdd269c52c0b2b1f76c60c.jpgIMG_20200830_111146.thumb.jpg.0b6ac6a7db60ff911ca4911f9579318a.jpg
Edited by SGT Grumbles
wrong image
It's not exactly clear from the pics which line it is, so I can't confirm part#.  However, it is unusual for those hoses to leak (of course nothing is impossible). I'd undo and then nip up the banjo bolt at the each end of the hose, and also the flare fitting at the back of the transfer case. Then degrease everything and check again after some driving.
If there is a light leak there, it's not the cause of your 4wd problem, there is nothing major in those pics.
If you replace that line you will need to refill the boot reservoir and rebleed the system. You can use any  good auto trans fluid, I use Castrol Syntrans in the race car but I don't know if that's available where you are. You could use a syringe to pull fluid out of the boot before you undo the line if you want to minimise the fluid that runs through.
Looking at it again last night with the top diagram, I'm pretty sure that's the right PN. I'll try loosening and re-tightening the banjo's just to see, but it looks like it's coming directly from the rubber portion of the line. You're right though a clean should help pin-point it.
Last night I tried topping up the system with some Castrol Dexron VI ATF. The AWD ran better but still felt like it was surging/slipping. I checked the reservoir and the fluid level was the same as when I filled it.
Is the surging/slipping when the AWD engages a typical sign of a different problem? I thought I lucked out with a leaky line. I'm hoping it's not the pump since those appear to be rather pricey.
In the meantime is it safe to cruise the car with the fuse pulled or does that risk wrecking the front/center diffs?
I'll take a look at the sensor tonight after work, see if I can see anything up with it. I know there is one guy with a GTR nearby, may see if he'll let me borrow his for a day.
Sounds like your transfer case is stuffed if it is slipping. Your friction plates are probably worn. It is completely possible to tear the material away from the plates due to incorrect or poor fluid.
On 01/09/2020 at 7:35 AM, Duncan said:
You can use any  good auto trans fluid, I use Castrol Syntrans.
Castrol Syntrans is a gearbox oil and is the correct oil for the gearbox, not the transfer or Attesa. Transmax Z is the ATF that should be used inside the transfers. Attesa fluid can be anything ATF basically dex iii upwards as it is just a hydraulic actuation fluid after all.
Also regarding any new Attesa hoses they are mostly all discontinued from Nissan and is now only available part of the Nismo heritage lineup.
22 hours ago, TXSquirrel said:
Your issue may also lie in the sensory side and not mechanical side.  What's the condition of your G-sensor?  Can you find another one nearby to test?
Just checked, one of the previous owners swapped it for a digital one. Looks pretty new, so I'm guessing that's not the issue.
Man that's a bummer if that's the issue. I'll drain and replace the trans/transfer fluids and see if there are any plate bits in there. Based on how the car feels when AWD engages I wouldn't be shocked if the clutch pack is worn out. Figured it had more life since there is only about 96k km's on it (assuming no rollback).
Are there any transfer case rebuild kits out there? I wasn't able to find anything when searching. Luckily there is a place nearby that rebuilds R32 GTR transfer cases if there aren't decent kits.
I'll let y'all know how the new fluids work out...and start budgeting for a transfer case rebuild lol. Oh well good excuse to swap clutch/fly wheel and get a new down pipe.
Yeah digital G sensor should be maintenance free.  Previous owner just saved you $400.
Your issue is mechanical then.  I was thinking, however, if the transfer case was slipping, why would it buck the car?  Because the rear wheels are still pushing, just the power not transmitted to the front.  So I would say do a quick check on the front diff. also, just make sure there is enough fluid and also the right fluid.
On 9/2/2020 at 9:40 PM, GTSBoy said:
Yeah. Nah. There is no such thing as an R32 with only 96 kkms. They all had at least that much 15 years ago.
a man can dream...lol
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
