I need help with what I should do with my diff it’s a Active LSD with a altessa pump system. It singles and I want to to double what can I do with this diff bleed it, weld it, get it shimmed, block off the altessa system? Idk what to do please help as I want to use my car for drifting / road use
https://www.sau.com.au/forums/topic/481063-r33-gtst-mspec-active-lsd-need-help/
So you didn't go and read about the active LSD as I suggested in the other thread ? In the drivetrain section there is a whole thread stickied at the top on the thing.
I could not find it sorry new to this site I’ll have another look
Basically you options are to bleed it and get it working back to factory 100%, or replace the entire housing, centre and driveshaft axles to go to any type of mechanical LSD. As mentioned earlier, ALL 33 and 34 GTR v spec have this type of diff too.
Basically you options are to bleed it and get it working back to factory 100%, or replace the entire housing, centre and driveshaft axles to go to any type of mechanical LSD. As mentioned ALL 33 and 34 GTR v spec have this type of diff.
Could I weld it ?
It actually astounds me that no one has ever produced a readily available LSD centre to go into the viscous LSD housing (unless I've missed something???).  A mechanical LSD diff housing is worth the GDP of a small African nation nowadays whereas a viscous LSD diff is worth a packet of Tim Tams and maybe a sneaky wristy no spit.  The person who makes it happen economically is going to make a lot of money and all of a sudden a near worthless hunk of boat anchor is worth money again!
If it's welded you could do nothing else as it's no going to "actuate' anything.
I know right ? I'd be the first one to get one for the v spec !
No. Not right.
There is little difference between VLSD and mech LSD (and in fact, the open diffs in NA cars etc) when it comes to the housing. There are literally dozens of mech LSD options for VLSD diffs. All of the usual suspects (Cusco, KAAZ, Nismo, etc etc, and many more) have mech diff replacements for VLSD and open R200 centres.
The only mech diff centres on any R chassis cars were the GTR 2-way mechanicals. And I suppose the helical diffs on some R34s can be consider mechanical too, just not in the same way. That's why they are rare and expensive.
What there is not, is something to easily put a mech centre into one of the ACTIVE diffs from the M-specs and V-spec GTRs. Because they make it difficult, and there was only a small number of them, and there are other diffs you can grab to put in their place.
  • Like 1
Wut? ..you're not including mechanicals i'm assuming.
39 minutes ago, tainer33 said:
If I welded it would I just put a bolt into the whole that the altessa bolts into?
I doubt that you could weld it. It's got hydraulic actuated clutches inside it and other shenanigans. Plugging up the hole where you pulled a hydraulic line out of it is the least of your worries!
And it is not altessa either. It's ATTESA. And what you have is not ATTESA. It is just active diff bullshit. ATTESA is 4WD. Which you don't have.
Huh??
1 hour ago, Shoota_77 said:
Sorry gents, I have to clarify.  I've been talking about diffs for the GT-R.  I don't know of an aftermarket mechanical centre for those.
Yeah, but still. GTRs only have 2 sorts of diffs.
The normal one is mechanical 2-way. No reason to talk about that any more.
The other is NOT a VLSD. It is the active diff. The V-spec diff. You are right, there are no mech centres to replace those, but there's also not very many of them out there, so why would anyone bother putting the effort into developing product?
I haven't looked on GTR registry for exact numbers, but that is far from correct. Off the top of my head about half of the 33 GTR is v spec with active LSD and in 34 GTR most of them have the active LSD. It is heaps rarer to have a 34 GTR with a non active mechanical LSD.
Yep, every one of these 34 GTR v spec, v spec ii,  N1, m spec and Nur spec have them. Even the halo Z tune has it, "specially tuned" as Nismo puts it.
Good in theory.
32 v specs 1 + 2 have the goods with the 31 spline mechanical LSD.
Yeah can't believe there is no a-lsd mechanical centre replacements after 25 years, they would sell like hot cakes
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
