Good Evening everyone hope you all well and keeping safe.
I am busy with a rb30/25 build and would like to finalize my build in the next 2 months however I am sitting with a little problem hopefully you guys can advise.
My questions is what is the max hp the stock Rb25det head bolts can handle?
I have been trying to source Arp head studs same as Rb25det  but Unfortunately none of the suppliers in Sount Africa have stock and are all waiting for containers to come in. Been about 4 months and i would like to start driving the car.
I have googled and came across a discussion that says they sitting at around 600hp on stock Rb25det head bolts. Not sure if this can be confirmed and if anyone has done something like this.
Build breakdown as follows:
Rb30 block
Stock 86.5mm pistons with Hastings rings
Stock rods but shot peened and Arp rod bolts
Rotating assembly balanced
Oil galleries drilled
Rb25det cosmetic head gasket
Acl main and big end bearings
Rb25det oil pump and flowed
New water pump
Rb25det damper pulley
1.5mm oil restrictors
Stock crank
Rb25det head ported and flowed intake and exhaust
Port matched intake
Rb26 valves,  quarters , retainers, valve springs, Lifters, cams cut 270
So the head is solid lifters and solid cams
Top mount branch pic attached built by Marius Fullboost South Africa
38mm waste gate
Greddy blow off valves
Stainless boost pipes
HKS Fuel rail
Lucas 1200cc injectors
2 x bosch 044
Turbonetics Hurricane 7868 aka Benita
Spitronics Mercury Fuel Management
That about where I am at the moment.
Any input as usual is appreciated and thanking you in advance for all the help and guidance so far with this build?
Thanks Brian Chev R
https://www.sau.com.au/forums/topic/481068-rb3025-max-hp-on-stock-head-bolts/
I would avoid the OEM head bolts, as they're TTY and should not be re-used.
Also they stretch pretty easy, so I would personally wait till you can get your hands on the ARP head studs/nuts.
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
