Not so much that a specific scan tool is needed, because the diagnostic protocol is industry standard. My argument is that the Nissan one gets straight into the meat and potatoes of it, especially since the software can diagnose JDM vehicles as well, and provide the clear definition of those diagnostic codes in Nissan-speak.
Some aftermarket scan tools have a limited range of vehicles in their database for directly translating the diagnostic codes to something in relative English, so they can give you a rough idea of what that affected device is but maybe not necessarily provide every finite detail to describe it.
I'm just thinking that two out of two dudes with aftermarket scan tools were pretty much bugger all help to you.
I'll talk to you in private. I may not necessarily solve your problem but we can at least drill down to what the culprit is likely to be.
So for the benefit of any keen readers here, this is what we've found so far:
  1. Battery is not really doing a great job at retaining charge. Fresh off a three hour charge or so, we saw only 12.1V and declining at a relatively brisk rate.
  2. Quick in-circuit current test showed a draw of around 200mA upon initial connect and then around half that soon after.
  3. Consult III+ software was showing 11.8V at the OBD port, while the battery was still measuring in slightly above 12.0V. After a few minutes, this dropped to 0.0V.
  4. No systems were powering up because we couldn't even get the car to switch the IGN power circuit (totally dead start button, including illumination), so no chance of the Consult II+ tool detecting any systems for testing.
While I have had my vehicle power up fine with the battery sitting on 11.9V or so, this is likely to be a bad battery. So the advice has been to charge the battery up, until the charger shows approximately 1A draw or less (indicating a fully charged battery). Disconnect from charger, let sit unconnected for 30 minutes or more, then measure the battery with a meter to see if it sits on or around 12.5V at least.
If the battery still sinks to around 12.1V or less, it's a dud and a warranty replacement should be obtained. If that still doesn't bring the car to life, the next step will be to check the IPDM, as it is responsible for feeding power to the multiple systems, including the OBD port.
Today's update:
Replacement battery was definitely MUCH healthier, measuring in at 12.66V.
Unfortunately, no change to the original problem though. Start button illumination is still dead. Checked the BCM, power is present at the BCM, the switch contact definitely has continuity to the BCM and grounds when depressed. However, the illumination pin is not being grounded by the BCM, which leads me to believe the BCM has gone bad here, as also indicated in PCS-64 of the G37 FSM.
This will need someone with a scan tool that has the immobiliser support (lacking in mine) to facilitate the replacement of a BCM.
Crazy sequence of events, but the issue ended up being the starter relay was faulty so Nissan replaced that and then the steering lock assembly was giving no response so they had to bypass that for me. If I want a new Steering Lock Assembly for the added security, they quoted me $2265 for the parts and to have them fitted. I'm happy for now to not worry about that too much.
So all in all, considering multiple services struggled to get any response from the vehicle, I dropped it off at Nissan on the 01/10 with no ignition and no ignition lights and got it back today 08/10 for $761 and everything is working fine. Pretty damn happy with that result.
If anyone else has a similar issue, I hope for your sake it is as simple as your Starter Relay being faulty.
Thank you everyone for your help!
Thank you for everything TheMax, you have been an insanely good help. Also thanks for updating the post for anyone else that is struggling with something similar, absolute LEGEND!
Edited by Scotterjay
TheMax
  • Like 1
Forums would be a lot more useful if more people did so. That's why we come here in the first place. It's just a shame that so many post here about their problems and then fall dead silent so that the rest of us can't learn a thing or two.
Granted, I'm not going to pretend that we're all entitled to everyone's knowledge after they've gone through the expense like Scotterjay did, as have the rest of us at one point or another, but I would argue, what's there to gain by keeping the cards close to one's chest when most of us don't do it for a living anyway?
  • Like 1
  • 2 years later...
I had a similar problem if the yellow and red key lights though non of the accessories was turning on including horn, lights even the doors could not central lock. After going through the knocking of the steering lock etc all in vain. When I was checking out the battery I realized that my right fuse on the positive battery terminal had blown. Did a power jump and the yellow light went off. Take a closer look at those 2 fuse
  • Like 1
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
    • I said "Matlab clone". I could throw one onto one of my linux VMs. Probably only take 10 or 20 hours to sort out the dependencies, relearn how to use it, etc etc.
