you can get red EL as well just a matter of asking for it I guess, might cost a lil more... if you just wanted red dials, change the lights in your cluster to red LEDs with resistors... should look stock but instead of white/yellowish you'll have bright red
https://www.sau.com.au/forums/topic/48109-illumiated-dials/#findComment-971853
the way EL works is a layer of luminescant is made to vibrate at a certain frequency, change the current and you'll change the frequency. Blue/Green is the easiest to make, but if you managed to get the luminescant to vibrate at the lower (or was it higher) frequency then it'll give out a red light. Of course the life of a Red EL is shorter than a blue one.
https://www.sau.com.au/forums/topic/48109-illumiated-dials/#findComment-971880
if you get a resistor with an LED you should be able to trick it up to the same voltage as a globe and wiggle it into the socket - bright LEDs will have that nice rice effect.
if you just want the basic EL kit.. www.modyourcar.com.au and a few places like that have them.. hideously overpriced ($250 or so) for what they are - but hey that is rice for you.
I have a spare cluster I have been playing with, but I still for the life of me can't work out how to get the needles off! I remember on my r31 cluster its very similar, and you just kind of pop them off.. but on the r32 cluster there seems a lot of resistance and I feel that if i pop the needle off its going to rip the spring or whatever is behind it out too ??
Is there a special trick to it? or do you just have to use a bit of careful force.
https://www.sau.com.au/forums/topic/48109-illumiated-dials/#findComment-972327
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
