39 minutes ago, Amin206 said:
We don’t have many options in Canada highest is 94 octane
Yeah but that's 94 AKI, which is really about 101 RON. Arguably our best unleaded here is BP ultimate 98 RON which has a 92 AKI. 9:1 will be fine.
  • Like 1
I spoke to the machine shop who resurfaced the head he’s also a builder he recommended 1.3mm head gasket over 1.5 as lower gap between squish pad and piston head will prevent detonation in higher rpm but he also said 1.5 isn’t too thick and should be fine too
i think I’ll get 86mm 1.3 gasket And cp 9:1 pistons for better response then I’ll measure piston to valve clearance if clearances were too close then I have no choice To get thicker gasket
ECUs have come a long way, there's no need to stress running higher than factory compression just as long as you have all your compensation strategies in place to pull timing and/or add fuel for (minimum):
  • IAT
  • Fuel temperature
  • Fuel pressure
  • Baro
  • Water temp
and you'll be fine.
  • Like 1
11 hours ago, Ben C34 said:
Measure stuff before buying things
If you mean cc’ing the combustion chamber how can I figure out how much the head skimmed by cc’ing ? We can figure out how much material (in cc) removed by measuring the volume of the combustion chamber right now minus the std volume but can we figure out how much the height of the head surface decreased? so then I can figure out some number to see if the valve hit the piston head or not...
if it’s not possible to calculate that then I have no choice to put something in there to measure...right?
Testing my memory and my maths skills at 4am; but I believe you would need to remove ~6.5 thou to drop the volume of the combustion chamber by 1cc. That won't be exactly correct, but quite close. So if you measured your head volume at 60cc, for example, you could work out that the head has been decked by roughly 25 thou. Which is quite a bit, and unlikely, but you just don't know.
That said, it is sort of more important to CC the head for the sake of correctly calculating your compression ratio. In order to work out your piston to valve clearances, you would be better served by doing a dummy assembly using your old gear (you only need to assemble 1 cylinder) and use that to measure your clearances as they were. Then with that knowledge, plus knowing the volume of your head, you can work out a good CR, what thickness headgasket you can use to achieve it, and what pistons you should be getting.
  • Like 1
Yesterday I ordered some stuff to cc the chamber so I’ll be able to get some numbers  tomorrow
also checking clearance with my old stuff wouldn’t be risky? I’m using a new block and not sure if previous builders decked the older block or not also can’t use the new block for measuring as my older pistons are 87mm and won’t go in there
Ok bad news is all exhaust valves are leaking instead of one chamber and I measured the chamber 3 times 2 times came up as 64.5cc and 3rd time Between  64.2cc to 64.1cc I would say the 3rd one was more accurate
but nothing less than 64cc for sure
if the the standard chamber is 64.5 then I don’t think they skimmed the head that much? Also machine shop told me the head looks new and doesn’t look like it’s been used that much like a 25 year old head... So there’s a possibility that previous builders used a new head
but the amount of carbon buildup on valves is actually a lot and I can tell the same thing on valve seats so might be the reason for leaking
  • Like 1
  • 1 month later...
Any recommendations for second ring gap ? Im at 0.019 for the top ring also during filling I noticed the black material On one of the top ring chipped
looks like another ring set? Does cp sell them separately or I have to get a set for all six cylinders?
  • 4 months later...
Hey guys my project is about to be done just wanted to say thank you to all who helped me here I’ve learned a lot.
I’m still taking my time measuring everything and building the engine by myself.
recently came up with this problem my k1 rod bolts are stretched i measured them after checking the clearance and I realized they are different in length by 0.003-0.004in Measured by arp stretch gauge and I decided to get new set but the problem is I can’t find rod bolts for my k1 rods
i called k1 and they said they used 3/8 with 1.6in underhead length but mine is definitely a 3/8 with 1.5in underhead length and I don’t think the previous builder changed the bolts as they have k1 tech arp2000 stamp on them
so I called arp and they recommended to get this part number 200-6207 which is also a 3/8 with 1.5in length but now that I got the package looks like the new bolts have longer thread length By 0.05in and  the head length where the socket goes is also taller
Looks like this is the only 3/8 1.5 arp2000 that is available right now maybe mine is an older version . I called k1 twice they don’t accept they have used 1.5in length bolt but one of tech mentioned they might have used 1.5 inches in some of them
Since nobody answered my questions and some people might have these questions and end up here from Google Search I asked my machinist who also does engine building  and familiar with rb26  he confirmed that rod bolt size might be different from each other +- 0.005in so probably I can still use my previous rod bolts and also there’s no problem with using the new set that I got so just to be safe I will use the new set cause if one of the old rod bolt changed its size more than 0.001in then it’s not recommended to be used.
also after calling k1 multiple times they can’t say whether they used 1.5 length rod bolts so probably they paid someone in China to design their rods. But for replacement always use same size rod bolts and same length and same material.
Also does anyone know how to use stretch gauge while installing the rods? Cause it doesn’t look like that main girdle let you put the arp stretch gauge in there
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
