So other night i did few hard braking and abs light is now on and no abs. Wheels do lock up
i have link g4 on my 1998 r34 gtt which has usb interface but i think that only replaces the ecu as I still have consult port
what I am not sure is if consult os reading and accessing ecu through the old ecu
so i bought consult and tried both consultz and nissan data scan 1 and neighbours can access the ecu or any other ecu as hicas was also removed
so i googled ans jumped pin 4 and 8 and still no flashing on abs light indicating what the problem is
read the link ecu and had no error and it is locked by tuner so can't access it
what are my options here to read abs fault and fix it?
Edited by drifter17a
https://www.sau.com.au/forums/topic/481120-abs-light-on-r34-skyline/
1 hour ago, drifter17a said:
Mechanic will have same tools as me
No. Take it to a mechanic who has a PROPER scan tool. Made by Snap-On, or any of the other $10000+ workshop grade scan tools that will connect to and read from EVERY make and model (with the appropriate licenses, of course).
Consultz and Nissdatascan etc are NOT proper scan tools. They are a valiant effort by talented amateurs.
right but where is the joy of fixing it yourself?
Link ECU replaces the main ecu as it is plug in so my question was does consult port uses the standard ecu to connect to hicas and abs etc / in another word, were you able to only access them throuugh standard ecu even though they were different ecus?
has anyone read abs module codes on nissan skyline and if so what software and port have you used
The joy is in getting the problem identified, because you cannot do it yourself unless you have drug money.
All CUs are on the same Consult bus. Access to the others is not mediated by the ECU.
I already told you - there is nothing out there. You need a workshop grade scan tool. This is a large handheld device that comes in a blow-mould case with a bunch of different cables that allows you to hook it up to diag ports on Nissans, Hondas, Toyos, BMWs......get the theme here? Or, you need an actual Nissan Consult tool. Same thing, just limited to Nissan only and more guaranteed to have the correct protocols and lookups for every Nissan.
There is only one diag port on your car. The Consult port.
Edited by GTSBoy
  • 2 months later...
Took it to two nissan dealer and they won't touch it as it has link ecu
thinking independent garage but haven't found reputable one
you can buy consult on ebay for relatively cheap price, does anyone know if there is a consult bus such as can so all ecus can be reachable via a bus lane without going through main ecu?
Yes, that is the definition of Nissan Consult. All the CUs are on the bus.
Any Snap-On, or similar scan tol, as possessed by ANY decent mechanic these days, WILL read all the CUs. I worked out what was wrong with my HICAS using a workshop grade scan tool.....20 years ago.
so I mapped the pins as per this link and my maxicom does not support it
https://www.autelstore.co.uk/wholesale/autel-maxicom-mk808-diagnostic-tool.html?gclid=Cj0KCQiAqo3-BRDoARIsAE5vnaKsLh-sn8cKvzkdH1CrqG3mb3u-DT01nvn1Y5rBSiwnTwzv8FPTw-MaAvC_EALw_wcB
it looks as I am out of any options, can't find any consult 1 or consult 2 reader.
as i understand consult 3 or consult 3 plus won't support my car. about to pull my hair.
https://www.chinatopcable.com/product/nissan-14-pin-to-obdii-16-pin-adapter-connector-cable-4-pin-pass-through-for-nissan-0-4-meters/
been to an indepdent garage today and he tried his tool but didn't work ..
done for the night but was thinking of trying combination below tomorrow
https://www.aliexpress.com/item/32672838945.html
or buy this?
https://www.cardiagtool.co.uk/svci-ing-infiniti-nissan-diagnostic-tool.html?gclid=Cj0KCQiAqo3-BRDoARIsAE5vnaKIkRaLcxMIuGeknqHBl1XS_QzSPEgs4-kWQSrL8QI9_WZiq885suUaAlYrEALw_wcB
  • 3 weeks later...
so here is my experience and update for people in similar situation
can read skyline r34 however doesn't have consult port adaptor.
so also bought below and confirmed it can read abs. I used the adaptor from consult to OBD and confirmed the Autel can also read the abs module.
I will map the pins using my multi meter and post back for anyone in similar situation in the future.
I saw a code saying ABS motor off, so back to basics, fuse was gone. Ouch that hearts by missing the most simple thing and going to get ecu to read it
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
