Hey y’all,
just got myself a new GReddy profec boost controller and installed it this afternoon. Started the car and let it warm up, everything was running fine, idling with no issues. Once she was warmed up, gave it a rev and instantly the engine cut out. Attempted to start again and it would just splutter a few time and cut out. Strong smell of fuel and also a lot of smoke coming out of the exhaust plus a lot of black liquid (not oil, I’m assuming fuel). I’m assuming the cars gone into limp mode as I’ve unplugged and removed the factory solenoid and it’s no longer getting a signal to the ecu?? Also being a 3 port solenoid that came with the GReddy profec, I’m assuming I’ll neeed to also take the car for a tune once I’ve worked out what’s going on. Currently running factory ecu for the moment, I have an apexi pfc w/ hand controller ready to go for when I can take it for a tune.
Any input into what may have gone wrong would be greatly appreciated.
thanks
Edited by Jakeeyjones
@Ben C34 Ah shit. So I’ve connected the vacuum port on the intake manifold to the GReddy sensor unit. Removed the factory solenoid and all the lines connected to it. Installed new solenoid, ran a hose from the actuator to one port on the solenoid and another hose to the fitting on the intercooler piping where the factory solenoid had a hose running to. Blocked the fitting on the stainless pipe where the bov plumbs back into the intake as I assumed I didn’t need that anymore after removing old solenoid. Tapped into the 12v acc for the controller and chassis ground. Like I said everything was running, didn’t change any settings on the boost controller. Simply turned the car on, warmed it up and gave it one rev to make sure the controller was getting a correct reading and that was it.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
