Cones Posted September 15, 2020 Share Posted September 15, 2020 As you may have seen in the Newbie section, I recently imported a beautiful, one-owner R32 from Japan and, wouldn't you know it, I spun a couple of bearings after just a week of driving. I wasn't planning to rebuild so quickly, but I guess that's how it goes with these cars. Because I was concerned about prolonging the life of the motor, I had already purchased a Haltech, Koyo radiator, fuel filter, spark plugs, wide band, boost controller, etc. - just the basics for a healthy stock motor - and was scheduled for a tune, but never made it that far. Fortunately I was just outside of the driveway when I felt it go so I was able to shut it down immediately, preventing a more catastrophic failure like a rod through the block. I debated tackling the rebuild myself with a mechanic friend who's a Nissan wiz, but ultimately decided to have it done by the pro's at Driver Motorsports in Virginia, USA. If you haven't already checked them out then do yourself a favor right now! Driver Motorsports Website & Driver Motorsports YouTube. I quickly fell way down the rabbit hole and this has turned into much more than I had originally planned, but isn't that how it always happens? My goal is to retain a fairly stock or OE appearance, but I need mo powa babeh! As I write this post the block is at the machine shop patiently awaiting it's turn, and I hope to have the car back with enough time to rack-up a few miles (km's) before winter is here. Fingers crossed! About the build: CP pistons (86.5mm) Manley rods JHH block brace ARP studs & bolts Tomei gaskets Nitto 1.1mm oil gallery restrictor Ross head drain Driver Motorsports custom catch can w/ sump drain Nitto oil pump Trust extended sump Twin low-mount 2860R-5’s ID1050’s w/ DW400 pump NGK 7’s Fluidampr crank pulley Oil filter relocation Haltech Platinum Pro ECU Koyo radiator Infiniti J30 fuel filter Apex-i pod filters AEM wide-band AEM boost controller Spec twin disc clutch Cube short shifter GKTech HICAS delete GKTech front uppers New inner & outer tie-rods All new poly bushings New rotors w/ Hawk pads Fresh tires (tyres?) Tomei cams, cam gears, and valve springs E85 conversion Fortune Auto coilovers 17" RPF1's Future Mods: Somehow address the transmission (likely just a set of gears) Maybe a big single turbo at some point (and bigger intercooler) Address the cosmetic issues of a nearly 30/yo car BBS LM's! Link to comment https://www.sau.com.au/forums/topic/481155-r32-gtr-engine-build-in-the-us/ Share on other sites More sharing options...
Cones Posted December 14, 2020 Author Share Posted December 14, 2020 Quick progress update: This process has taken much longer than anticipated, but the end is finally near! The machine work was recently completed and the engine is being assembled. Since I've waited this long I decided not to postpone the cams and E85, so on with Tomei 262 cams and a set of Tomei springs and cam gears. Chassis mods include Fortune Auto 500 series coils, a set of 17" RPF1's, GKTech front upper control arms, new OEM tie-rods, and GKTech HICAS delete. Here are a few pics of the progress (the car on the lift is prior to coilovers being installed). I can't wait to get behind the wheel again! 4 Link to comment https://www.sau.com.au/forums/topic/481155-r32-gtr-engine-build-in-the-us/#findComment-7944439 Share on other sites More sharing options...
SiR_RB Posted December 15, 2020 Share Posted December 15, 2020 Awesome work keep us updated with more pics ! 1 Link to comment https://www.sau.com.au/forums/topic/481155-r32-gtr-engine-build-in-the-us/#findComment-7944481 Share on other sites More sharing options...
E33 Posted December 15, 2020 Share Posted December 15, 2020 That's one friggin deep rabbit hole - lol You only live once - drive it and enjoy it 1 Link to comment https://www.sau.com.au/forums/topic/481155-r32-gtr-engine-build-in-the-us/#findComment-7944496 Share on other sites More sharing options...
Cones Posted December 29, 2020 Author Share Posted December 29, 2020 She's coming along! The waiting is the hardest part... 1 Link to comment https://www.sau.com.au/forums/topic/481155-r32-gtr-engine-build-in-the-us/#findComment-7945106 Share on other sites More sharing options...
