As you may have seen in the Newbie section, I recently imported a beautiful, one-owner R32 from Japan and, wouldn't you know it, I spun a couple of bearings after just a week of driving.  I wasn't planning to rebuild so quickly, but I guess that's how it goes with these cars.  Because I was concerned about prolonging the life of the motor, I had already purchased a Haltech, Koyo radiator, fuel filter, spark plugs, wide band, boost controller, etc. - just the basics for a healthy stock motor - and was scheduled for a tune, but never made it that far.  Fortunately I was just outside of the driveway when I felt it go so I was able to shut it down immediately, preventing a more catastrophic failure like a rod through the block.
I debated tackling the rebuild myself with a mechanic friend who's a Nissan wiz, but ultimately decided to have it done by the pro's at Driver Motorsports in Virginia, USA.  If you haven't already checked them out then do yourself a favor right now! Driver Motorsports Website & Driver Motorsports YouTube.  I quickly fell way down the rabbit hole and this has turned into much more than I had originally planned, but isn't that how it always happens?  My goal is to retain a fairly stock or OE appearance, but I need mo powa babeh!  As I write this post the block is at the machine shop patiently awaiting it's turn, and I hope to have the car back with enough time to rack-up a few miles (km's) before winter is here.  Fingers crossed!
About the build:
CP pistons (86.5mm)
Manley rods
JHH block brace
ARP studs & bolts
Tomei gaskets
Nitto 1.1mm oil gallery restrictor
Ross head drain
Driver Motorsports custom catch can w/ sump drain
Nitto oil pump
Trust extended sump
Twin low-mount 2860R-5’s
ID1050’s w/ DW400 pump
NGK 7’s
Fluidampr crank pulley
Oil filter relocation
Haltech Platinum Pro ECU
Koyo radiator
Infiniti J30 fuel filter
Apex-i pod filters
AEM wide-band
AEM boost controller
Spec twin disc clutch
Cube short shifter
GKTech HICAS delete
GKTech front uppers
New inner & outer tie-rods
All new poly bushings
New rotors w/ Hawk pads
Fresh tires (tyres?)
Tomei cams, cam gears, and valve springs
E85 conversion
Fortune Auto coilovers
17" RPF1's
Future Mods:
Somehow address the transmission (likely just a set of gears)
Maybe a big single turbo at some point (and bigger intercooler)
Address the cosmetic issues of a nearly 30/yo car
BBS LM's!
https://www.sau.com.au/forums/topic/481155-r32-gtr-engine-build-in-the-us/
Quick progress update:
This process has taken much longer than anticipated, but the end is finally near!  The machine work was recently completed and the engine is being assembled.  Since I've waited this long I decided not to postpone the cams and E85, so on with Tomei 262 cams and a set of Tomei springs and cam gears.  Chassis mods include Fortune Auto 500 series coils, a set of 17" RPF1's, GKTech front upper control arms, new OEM tie-rods, and GKTech HICAS delete.
Here are a few pics of the progress (the car on the lift is prior to coilovers being installed).  I can't wait to get behind the wheel again!
  • Like 4
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
