i want to have a turbo skyline but currently have bodykit etc on myne so don't want to sell. what are the main differences besides engine wise (brakes, etc) from a turbo to a n/a r33 skyline. also would it be more effective to do a complete engine swap for a rb25det and does anyone know where's the best place to grap one and can they trade the old one in? cheers guys
https://www.sau.com.au/forums/topic/48117-rb25de-change-to-rb25det/
This can be an expensive exercise (I just did it but at mate's rates). Gearbox is different, tailshaft, brakes, wiring loom. Many will advise against it as the cost will be the same as buying a GTST (take the body kit off of the n/a and put it on the GTST). I did it as the standard GTST would not have met my requirements. I would have changed a lot of things anyway (turbo, ecu, intercooler). I didn't put a turbo on the rb25de as I believe it wasn't strong enough so I sourced a rb25det. This probably doesn't answer your questions but might give you something to think about.
Being in the same situation, here's how I justified buying a front cut and putting it in:
1) Even though it may be cheaper to buy the turbo version, you don't know the history of the car, i.e has it been crashed, how good is the engine etc. It may be cheaper to do an engine transplant in your current car in the end;
2) Insurance is generally cheaper for an N/A car with a turbo;
3) Having to stuff around finding a car that you like, is in good condition, and then eventually selling yours. Add to that stamp duty etc. May be easier just to find a front cut.
I will be doing a swap in my R34 very soon, and have no regrets about deciding to do so.
My two cents.
a front cut is bascially the front part of the car upto the windscreen. say in japan some dude writes off an r33 gtst, the rear end is absolutely mashed, front is fine. get a big cutter thing chop car in half from windscreen to the front and ship it over to aus. you pay say $4000 for the front cut and you get engine, wheels, brakes, gearbox, full panels, lights etc providing they are ok and not busted etc and you can pick what parts u want and sell the leftovers if you like
this way you get the turbo model parts of thingsl like full engine, ecu, intercooler, front brakes, geatrbox, engine mounts etc.. as apposed to simply bolting the turbo charger onto a n/a engine, you swap all parts over
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
