Ok so got the r32 manual so thanks for the advice
few questions:
1. why is the torque in range such as 85-110? That is a huge difference
2.you can't put a torque meter on the flange from gearbox so i made it as tight as I could with spanner. Book says torque should be 80 nmwhich seems very high for that bolt and nut
 3. Subframe torque was 110nm , lock is not nylon so you don't need to dispose of it, re use? I used medium strength loctile on it
https://www.sau.com.au/forums/topic/481178-r34-bolt-torque/#findComment-7940484
Torque range because it clearly doesn't matter so much where it ends up.
I don't understand "flange from the gearbox". Do you mean the input flange on the diff at the back end of the tailshaft? Most people just do bolts like that up as tight as they can manage with a regular ring spanner and say "click".
I always just re-use subframe fasteners. Shit never comes off.
  • Like 1
https://www.sau.com.au/forums/topic/481178-r34-bolt-torque/#findComment-7940702
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
