Hi all, I am now running atr45sat with stock dump, hks front pipe, stock cat(empty inside ) , trust pe2 catback on my gtt. Only manage to get round 350 [email protected] told me to the main issue is the dump pipe. I have a few options in my mind now, wishing to seek advise from experts here.
1: possible to get a 3inch elbow dump (tomei/hpi) to pair up with my hks front pipe and  a xforce  hi flow cat?
2: hks elbow dump ,hks front pipe ,xforce hi flow cat.
3:tomei/hpi elbow , with Japspeed full 3inch front pipe, xforce hi flow cat
my concern is the fact that the inlet of my hks front is 2.5 Inch, only the outlet is 3inch, if I use a 3inch elbow, will it affect the flow? (That’s why I am contemplating to get the japspeed front pipe, looks like it’s 3inch both inlet and outlet )
Ps:due to local authority restriction , I need to have my cat intact , and I cannot do ewg.
any advise will be greatly appreciated
Edited by gimmelovetattoo
Well, it’s really a pain in the ass for car modification here. Yes I can run a cat with single piece bell mouth, but since the oem part come with elbow and a connecting front pipe, I am not allowed to change to a single piece . Therefore my options are limited , and I wish to make the best out of the limited options, so any more advise will be greatly appreciated !
Fitting a bigger turbo is somewhat in the grey zone, usually if it’s still on factory’s mounting position, you can get away with it. As for the exhaust system, they are super strict with it, we are only allowed SOME jasma approved catback . And as for front pipe, I am using hks, but I wrap it with the stock shield . I am located in Singapore .
That's our GTSBoy, doesn't just think outside the box; he cuts the box in half and puts a flange on it. Ideal way to go.
For a real oem look, you could even weld on some brackets to the dump and bolt the stock heatshield to it....possibly.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
