Looking for a little electrical help. I have a hcr32 on a Nistune ecu that at first, had problems with holding connection to the software even with the key only in the on position with the engine off(so not an electical noise issue). Now, I cannot connect to the ecu at all with Nistune, or data scan software. I have tried different cables, different laptops, even re-wired a new consult port in. After that I tired the paper clip jump trick to get codes to flash and nothing worked. I have just got another oem ecu, and still have no luck. I’m quite stuck now and id appreciate any help. Thanks
Edited by smart_garrett
https://www.sau.com.au/forums/topic/481195-no-ecu-working/
19 minutes ago, robbo_rb180 said:
Does the car start and run?
If ecu is not getting power check ECCS relay and associated fuse
If just a communication issue test the continuity of the wiring from the consult port to the ecu
The car starts and runs great. I also tested the wiring from the consult port to ecu and everything was good, even rewired a new port and still no luck.
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940544
ok, double check the continuity/resistance of the consult plug wiring and correct connections at ecu and port.
Have a re-read of this Nistune Diagnostic/Connection issue guide
https://nistune.com/docs/Installation_and_Communication_Diagnostics.pdf
consult port wiring guide
http://nistune.com/docs/MAF_and_Consult_pinouts.pdf
for it to be an issue with the factory ecu in my opinion it is a wiring/pinout issue
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940547
The consult wiring guide is the guide I used to rewire my consult port to a new wiring specialties pig tail. I have 12v and a ground, but I’m not sure what I should be seeing at the Rx, tx, and clk connections, if anything.
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940548
14 hours ago, GTSBoy said:
Nothing that you can see with a multimeter. That's a serial link. You're talking digital data at many kbaud.
That’s what I was thinking that’s why it’s hard to see if it’s receiving or transmitting data.
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940614
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
