Looking for a little electrical help. I have a hcr32 on a Nistune ecu that at first, had problems with holding connection to the software even with the key only in the on position with the engine off(so not an electical noise issue). Now, I cannot connect to the ecu at all with Nistune, or data scan software. I have tried different cables, different laptops, even re-wired a new consult port in. After that I tired the paper clip jump trick to get codes to flash and nothing worked. I have just got another oem ecu, and still have no luck. I鈥檓 quite stuck now and id appreciate any help. Thanks
Edited by smart_garrett
https://www.sau.com.au/forums/topic/481195-no-ecu-working/
19 minutes ago, robbo_rb180 said:
Does the car start and run?
If ecu is not getting power check ECCS relay and associated fuse
If just a communication issue test the continuity of the wiring from the consult port to the ecu
The car starts and runs great. I also tested the wiring from the consult port to ecu and everything was good, even rewired a new port and still no luck.
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940544
ok, double check the continuity/resistance of the consult plug wiring and correct connections at ecu and port.
Have a re-read of this Nistune Diagnostic/Connection issue guide
https://nistune.com/docs/Installation_and_Communication_Diagnostics.pdf
consult port wiring guide
http://nistune.com/docs/MAF_and_Consult_pinouts.pdf
for it to be an issue with the factory ecu in my opinion it is a wiring/pinout issue
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940547
The consult wiring guide is the guide I used to rewire my consult port to a new wiring specialties pig tail. I have 12v and a ground, but I鈥檓 not sure what I should be seeing at the Rx, tx, and clk connections, if anything.
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940548
14 hours ago, GTSBoy said:
Nothing that you can see with a multimeter. That's a serial link. You're talking digital data at many kbaud.
That鈥檚 what I was thinking that鈥檚 why it鈥檚 hard to see if it鈥檚 receiving or transmitting data.
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940614
